whats too hot for a c5?
Old Jun 16, 2009 | 11:07 PM
a/c man's Avatar
a/c man
Default whats too hot for a c5?
i hope someone can tell me what temp a c5 procharged should be @ today in texas @ 99 out side my car on a 2 hr trip saw temps of 220-238 with the a/c on and 212-220 with it off my auto trans was 220-255 i have a 186 t-stat what do you think thanks scott
Old Jun 16, 2009 | 11:18 PM
AnotherPewterVette's Avatar
AnotherPewterVette
Mine goes just a high when im going slow in traffic. IDK if its good tho?
Old Jun 16, 2009 | 11:20 PM
mitchell c's Avatar
mitchell c
Those temps are a bit warm. Have your fans programed to come on sooner to maintain lower engine temps. A thermostat by it self won't help much to lower engine temps if your fans are not coming on until you are above 220-230 degrees. You might also want to consider a tranny cooler 220-255 is warmer than I would want my tranny to be. Mine stays below 200 degrees.
Old Jun 17, 2009 | 12:04 AM
zoomz's Avatar
zoomz
255 on a tranny is pushing limp mode and not good at all .
Engine temp is at the edge of safety .
Never let it hit 240 .
Old Jun 17, 2009 | 12:07 AM
a/c man's Avatar
a/c man
i even put a trans cooler on it
Old Jun 17, 2009 | 12:12 AM
zoomz's Avatar
zoomz
Do you have a seperate fan for the tranny kooler ?
My tranny kooler sucked untill i put a fan on it , then my temps hovered around 170-190 .
Old Jun 17, 2009 | 12:25 AM
a/c man's Avatar
a/c man
yes it is the one with a small fan flexlite i mounted it to the condencer also i have a 3600 stall that may make it hotter with the a/c off the trans went down to 205
Old Jun 17, 2009 | 12:51 AM
zoomz's Avatar
zoomz
The 3600 is probley the culpret .
Im at 3200 and only see high temps when sitting in stop and go traffic .
Old Jun 17, 2009 | 01:03 AM
a/c man's Avatar
a/c man
i even got a new aluminum Howe radiator with no trans cooler and it made no change in the temp my tuner reset my fans to both come on @ 180 i was thinking my a/c may have too much head pressure and making the condenser too hot and the trans cooler that is mounted to it also the radiator what would you think thanks Scott
Old Jun 17, 2009 | 01:10 AM
zoomz's Avatar
zoomz
Its hard to say .
When the ground temp gets high and your driving on black top pavement , things just get hot .
When its 95 degrees in florida the pavement is probley 120 or so and its hard to keep a car kool .
Ask your tuner to figure it out .
Old Jun 17, 2009 | 01:13 AM
a/c man's Avatar
a/c man
Its hard to say .
do you think a lower car gets hotter then on the hot @ss black top!
Old Jun 17, 2009 | 01:15 AM
zoomz's Avatar
zoomz
Was your air dam changed when the pro charger was installed ?
That might be worth looing into .
Old Jun 17, 2009 | 01:18 AM
a/c man's Avatar
a/c man
thanks thats a good call ill check that out! it is a rubber flap now!from procharger
To whats too hot for a c5?
