Need Help in diagnosis!
Old Jun 27, 2009 | 11:37 AM
Bakersfield's Avatar
Bakersfield
Have you ever changed the fuel filter? It could be starving for gas when you get on it.
Old Jun 27, 2009 | 11:53 AM
cam99's Avatar
cam99
It's running better when I jump on it now, it's part throttle now that an issue.
I should change the gas filter though, I think it may be the MAF now.
I'm waiting till it cools down to change the Plugs and wires.
Old Jun 30, 2009 | 09:35 AM
Zeeohrix's Avatar
Zeeohrix
I had problems with mine also running little rough some slight backfire , check the resistance in the spark plug wires, I found 3 wires with too much resistance , and they where only 3 years old MSD wires, replaced them with Taylor Thunder 10.5mm wires , and its running almost perfect.
Old Jun 30, 2009 | 09:47 AM
cam99's Avatar
cam99
I used Talyor wires, I think they may be almost 3 years old. I got the GMPP wires to install and plugs (NGK TR55).
I'll change them and see what happens.
Thanks for your input.
Old Jun 30, 2009 | 08:37 PM
crainholio's Avatar
crainholio
Let us know how it responds to the new parts, and what you observe on the old plugs in terms of coloration and deposits.
Old Jul 2, 2009 | 03:47 PM
cam99's Avatar
cam99
I have some codes now:
BO-RFA
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
I did reset the PCM for fuel trim.
Then I reset the codes, but now they come back.
Old Jul 6, 2009 | 10:08 AM
cam99's Avatar
cam99
ttt
see post 26
Old Jul 6, 2009 | 02:17 PM
cam99's Avatar
cam99
Found a burnt wire, original problem resolved.
Thanks guys
