Differential Torque Specs?
Old Jun 17, 2009 | 01:44 PM
96mogt's Avatar
96mogt
Default Differential Torque Specs?
Im doing the hardened output shaft swap and I found the torque for everything but the actual bolts that mount the longer output shaft with the clutch pack to the larger gear. If anyone can help that would be great!! Thanks, jay
Old Jun 17, 2009 | 05:16 PM
AllVette's Avatar
AllVette
For the 10 bolts that hold the internal housing together the torque spec is 55 N·m (41 lb ft.)
Old Jun 18, 2009 | 07:09 AM
96mogt's Avatar
96mogt
Thank you!!
To Differential Torque Specs?
