Clutch Slave Cylinder Quick Disconnect!!!!
Old Jun 18, 2009 | 10:20 AM
96mogt's Avatar
96mogt
Default Clutch Slave Cylinder Quick Disconnect!!!!
Hey guys,
I just completed my clutch swap along with an assorted of other mods here and there. I cannot get my clutch quick disconnect to snap back together. What am i doing wrong?? Its driving me nuts and this is the last thing i have to do to test and drive the car lol....Any help would be great! Jay
Old Jun 18, 2009 | 10:33 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
push harder, maybe the clutch is ill fitting and pushing against the slave causing pressue on the line?? just a guess
never had this problem, take a look at the oring also
Old Jun 18, 2009 | 10:40 AM
96mogt's Avatar
96mogt
The O ring looks fine, thats what i was thinking about the press in the line that i should bleed out from the other port when i go to put it back on. Ill try today and hopefully ill get it in there. Jay
Old Jun 18, 2009 | 10:41 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
push harder! it isn't easy to get together in my experience
Old Jun 18, 2009 | 10:44 AM
96mogt's Avatar
96mogt
Ok sounds like i need to throw alittle more MAN to it I just wasnt sure how hard this thing was to get to snap back in. Obviously pretty darn hard. Thanks, Jay
Old Jun 18, 2009 | 10:51 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I remember using some really big/odd shaped pliers to get the job done. but that probably wasn't a good idea looking back, lol
Old Jun 18, 2009 | 12:38 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I used a pair of channel lock pliers to squeeze it together. It was easier to get together than to get apart. Sounds like some of my past relationships.
Old Jun 18, 2009 | 01:27 PM
96mogt's Avatar
96mogt
LOL.. No Comment!
Old Jun 18, 2009 | 02:54 PM
HP_Addict's Avatar
HP_Addict
Crack the bleeder screw on the slave and it will push together easier. You are fighting hydraulic pressure.
Old Jun 18, 2009 | 03:29 PM
96mogt's Avatar
96mogt
Got it, thanks guys.. Works great!!!! Jay
Old Jun 18, 2009 | 06:11 PM
speedyhawk101's Avatar
speedyhawk101
Had this happen before and you are correct. I bench bled the Master and slave and then assembled the tranny.....
Went to connect the quick disconnect and I fought that bastard for a while before this dawned on me. Crack the bleeder and let off just a tid-bit of pressure. Worked like a Champ!
To Clutch Slave Cylinder Quick Disconnect!!!!
