01 Z06 misfiring
Old Jun 19, 2009 | 05:27 PM
Zeeohrix's Avatar
Zeeohrix
Default 01 Z06 misfiring
So I'm getting a slight vibration at around 2300RPMs, and I also can feel it in neutral while holding my revs at around 2300RPMs , and sounds like there is a misfire and shake , just enough to be noticable.
I notice it cause it always ran very smooth threw the RPMs, until now.
Ive treid new spark plugs , but still the same thing. could it be a coil pack? is there any way of checking or testing coil packs? Or does anyone think its something else?
The engine does have some mods such as a cam , intake ,TB , long tube headers, and high flow cats with X pipe.
Old Jun 19, 2009 | 07:20 PM
MTPZ06's Avatar
MTPZ06
Does it idle fine? Have you listened to it idle standing over the motor with the hood open?
It may very well be a coil pack, but I haven't heard of too many going bad unless you have those crappy MSD coil packs. Not sure if they can be tested for resistance with an Ohm meter or something?
Hang in there, I'm sure some very tech savy folks will chime in shortly...just keep your thread up to the top.
Old Jun 19, 2009 | 08:04 PM
Zeeohrix's Avatar
Zeeohrix
Thanks , could it be too large of a spark plug gap? whats the recomended spec ?
Old Jun 19, 2009 | 08:20 PM
cam99's Avatar
cam99
I have a similar problem at almost the same RPM's, I think it may be bad gas.
Does it bog, when you jump on it?
see http://forums.corvetteforum.com/c5-t...diagnosis.html
Old Jun 19, 2009 | 08:24 PM
Zeeohrix's Avatar
Zeeohrix
I just filled it again with fresh tank of fuel , and don't feel any bogging , but i still feel the slite shake at around 2300rpm then feels smoother after 3000rpms, power is still strong and responsive .
Old Jun 19, 2009 | 09:03 PM
Blown 346's Avatar
Blown 346
Have you replaced the wires? They can have small hair line cracks which will cause them to mis and arc.
The Spark Plug gap for a N/A motor is .055
Old Jun 19, 2009 | 09:36 PM
Zeeohrix's Avatar
Zeeohrix
Even a cammed motor? gap at .055?
Old Jun 30, 2009 | 09:26 AM
Zeeohrix's Avatar
Zeeohrix
replaced the spark plug wires with a set of Taylor 10.5 mm wires , runs alot smoother at 2000rpms , and barely any mis-fire now .
To 01 Z06 misfiring
