A little help with DRL install please
Old Jun 19, 2009 | 06:03 PM
olefam's Avatar
olefam
Default A little help with DRL install please
Not sure if this post is in the right section. If not, I appologize in advance.
Just got DEPO clear corner lights for the 04 coupe. Two questions -
1) I'd like to use LED switch back bulbs. But there seems to be some controversy about the 60-lamp bulbs. Burn out fuses and such. Which LEDs are others using without issues?
2) If you have installed these clear corners on your car, is there anything difficult or easily broken that I should watch out for? How much time should this job be expected to take?
TIA.
Glen
Old Jun 19, 2009 | 10:43 PM
olefam's Avatar
olefam
Please???
Old Jun 19, 2009 | 11:32 PM
byronhunter's Avatar
byronhunter
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Release the brake caliper cooling duct from the front fascia, and position the duct aside.
Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
Remove the lamp bracket retaining spring from the front fascia.
Remove the front turn signal lamp bracket retaining screws.
Disconnect the sockets from the lamp.
Remove the lamp, with the bracket, from the vehicle.
Remove the lamp to bracket retaining screws.
Remove the lamp from the bracket.
Installation Procedure
Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the front park/turn signal and sidemarker lamp to bracket retaining screws. Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N·m (18 lb in).
Install the sockets to the lamp.
Install the lamp, with the bracket, to the front fascia.
Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws. Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N·m (27 lb in).
Install the lamp bracket retaining spring to the front fascia.
Install the front turn signal lamp bracket retaining spring to the lamp bracket.
Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers
Old Jun 20, 2009 | 08:25 AM
olefam's Avatar
olefam
Thank you.
Does anyone know if the 48 light LEDs have the same "fuse blowing" issues as the 60s? I know several of our vendors sell these units, but I didn't save the information when I read it.
Again, any information would be greatly appreciated.
Glen
To A little help with DRL install please
