I have a hole in the rear evaporator line high pressure side.
i have hade the part on back orded for what seems like forever(elkers) any one have an idea on what it is going to take to replace this line.
If it's the one that bolts the firewall, the only time I've had a good look at it was when the engine was removed. That one looks to be a bear with the engine installed.
Ive done this line when changing my a/c compressor and it wasn't the most fun I've had working on the Vette. I got my line from the local Chevy dealer, and just so you know a backorder at Ecklers can take a very long time (I have multiple parts on backorder right now and my hood that wasn't backordered took a month). But, you remove the battery to get to the back side of the line, and you take it off the compressor by removing your pass. front tire and using a loooong extension and universal and 13mm (?) off the back of the compressor. It is a 2 piece unit, and of course replace the filter in the line with a new one. I did it without removing the headers or anything else, but it was a long job since the compressor is a really tight fit. It's doable though, but the dealer charges a lot of time for that job. I would suggest heading to you friendly local dealership for the parts personally if you want your a/c back. good luck
If you're mechanically inclined, its really not that hard of a job and I see youre in port charolette.....um it was 97 in Tampa today, get that a/c fixed asap! I did mine 2 months ago when I couldn't go windowless anymore (have an frc, can't go topless)
yes it is too hot to even drive it during the day. I am mechanical inclined so if I ever get the part I will tear into it. I think the intake will have to come off. Is there anything else I should look into while its apart.
