installed CLB, same problems
Old Jun 23, 2009 | 07:02 PM
99mikeb's Avatar
99mikeb
Default installed CLB, same problems
Okay,just received the CLB from thunder racing and installed it and still having fuel shut off and the same two DIC, pull key and service column lock.I have done everything possible check battery voltage,clean key vat
check all fuses,clear codes,disconnected battery for half hour, anything I'm missing?
I guess I have to make appointment with a tuner,but I would like to be able to drive the car there instead of having the car towed.MY last tow messed up my front nose of my car,because clearance.HELP
Old Jun 23, 2009 | 10:48 PM
540 vette's Avatar
540 vette
I had the same thing. CLB didn't work. I sent my PCM and had the 1.5 mph tuned out. Car works but I still get the codes.
After reading 1,000,000 posts I have come to the conclusion that nobody knows why it happens and nobody knows how to fix it. As far as I am concerned the CLB is just a bandaid...if it works for you.
Old Jun 24, 2009 | 06:36 AM
dougbfresh's Avatar
dougbfresh
It's most likely the IGNITION SWITCH not reading the key well.
Old Jun 24, 2009 | 11:00 AM
540 vette's Avatar
540 vette
How does the ignition switch have anything to do with the car cutting off at 1.5 MPH.
Old Jun 24, 2009 | 11:22 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Not true, I told you what you have to do to fix it. But you chose not to listen....
Old Jun 24, 2009 | 02:57 PM
540 vette's Avatar
540 vette
I had a local tuner do that. And I still have the problem with the codes. Now what.........
This all started because my battery went low.
Old Jun 24, 2009 | 03:00 PM
540 vette's Avatar
540 vette
Originally Posted by 8VETTE7
Obviously you have NO understanding of how the column lock system works or you wouldn't have made this statement...........
You may be right but don't be a phucking wise *** about it.
Old Jun 24, 2009 | 03:17 PM
dougbfresh's Avatar
dougbfresh
If the pellet on the KEY is not being READ correctly the SECURITY SYSTEM kicks in (which is what's really going on here). GET IT NOW? When the lock was tuned out or removed, the only security you now have is the fuel cutoff to keep a thief from getting away once they start the car. If the key's not read correctly-it thinks your the bad guy.
How did you think the resistor pellet gets read??
Old Jun 24, 2009 | 04:58 PM
99mikeb's Avatar
99mikeb
Should I pull the key switch apart?I read that thread Bill Curley did about the key switch.Do you think the key not right.I have 2 keys and check both of them and the second key is brand new.It's the correct VAT pellet,any thoughts
Old Jun 24, 2009 | 11:03 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
What did your "local tuner" do to the PCM?
Old Jun 26, 2009 | 09:39 AM
540 vette's Avatar
540 vette
Lets see...... I bought a used PCM for my car and gave the car and the new PCM to him and he took it to the Chevy dealer where he works and put the other PCM into it and programmed it for my car. I still got the DIC codes. He then put my original PCM back in with the performance tune. Maybe the next stop is changing the BCM.
Old Jun 26, 2009 | 09:58 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Are you sure 100% your friend flashed a program that was not updated with any recalls? Being that he did it at a GM dealership, I suspect all their programs are already updated with the effed up version. (recall 2)
On my PCM, I have GM recall number 1 (done without my consent) and the CLB. No DIC codes, No fuel cutoff, and no column lock!
To installed CLB, same problems
