99 vert power windows and locks again
Old Jun 23, 2009 | 07:49 PM
coyote 70's Avatar
coyote 70
Default 99 vert power windows and locks again
My passenger side was intermittment so I installed an new DCM and it worked for awhile so I wiggled the wires between the door and the door jam. Now the locks and power windows do not work on either side. I scanned codes and I get the following
10-PCM
38-RTD
28-TCS
40-BCM
58-scm
60-IPC
80-radioA-pdcm-no communication
and I probably missed a few as they were going by.
Any suggestions?
My next thought was to take it to the dealer.
Old Jun 24, 2009 | 01:25 PM
timemender's Avatar
timemender
Seems that you are on the correct path - or at least the most logical starting point.
Those connectors in the door hinge areas (BOTH SIDES) need to be addressed first.
See link below
Post #316
http://forums.corvetteforum.com/c5-t...n-long-16.html
Clear all codes and see what comes back. The DIC will read out the codes first in automatic mode then in "manual" mode in which you can record them at your own pace.
Post the codes if additional help is needed.
