Electrical connector for CAGS
Old Feb 10, 2002 | 06:21 PM
C5illness's Avatar
C5illness
Default Electrical connector for CAGS
What type of connector is used on the CAGS connection on the transmission of a C5? It's the weather proof one that is used all over the GM cars. Also, does anyone know where I can get some?
Thanks,
C5illness
:chevy
Old Feb 10, 2002 | 06:58 PM
Charlie LI NY's Avatar
Charlie LI NY
Default Re: Electrical connector for CAGS (C5illness)
Go to the MALL pull down, look under Group Purchase, you will find the part there then check out this web site http://www.97vette.com.
It is very easy to install takes about 5min.. :chevy
[Modified by Charlie LI NY, 6:00 PM 2/10/2002]
Old Feb 11, 2002 | 12:42 AM
C5illness's Avatar
C5illness
Default Re: Electrical connector for CAGS (Charlie LI NY)
Hi Charlie LI NY,
Are you talking about the CAGS eliminator product? That has the connector that I'm looking for. I want to know what type of connector that is. What is the connector called. Maybe C5TECH can answer this?
C5illness
:chevy
[Modified by C5illness, 10:43 PM 2/10/2002]
Old Feb 11, 2002 | 11:51 PM
C5illness's Avatar
C5illness
Anyone know?
C5illness
:chevy
Old Feb 12, 2002 | 12:43 PM
Paul2001's Avatar
Paul2001
http://www.delphiauto.com is the manu, http://www.pios.com may be able to sample / sell you want you want.
I have found in the past that the part numbers for the connectors can be a little hard to figure out. Some connectors may not even be available.
good luck !
Old Feb 12, 2002 | 03:52 PM
gbm's Avatar
gbm
$10 says it's a GM/Delco 'proprietary' connector
Old Feb 12, 2002 | 06:25 PM
Paul2001's Avatar
Paul2001
Default Re: Electrical connector for CAGS (gbm)
I don't know if I will take that bet -- but now I am curious myself.
I have the catalog right here --- is that connector 6 pins in a line ?
I has been a while since I did my cags.
Old Feb 12, 2002 | 06:59 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Like most exterior connectors,it is a weatherpak connector...A "good" GM parts counter man can look up the p/n for any connector....
Old Feb 12, 2002 | 10:38 PM
LT1GMC's Avatar
LT1GMC
Its a 2 pin weatherpack.
To Electrical connector for CAGS
