Coolant temp sensor issue...
Old Jun 24, 2009 | 03:08 PM
RideZX6R's Avatar
RideZX6R
Default Coolant temp sensor issue...
So I installed headers and when I did we broke the collant temp sensor thats on the head (driver's side).
We installed a new one and now I get a coolant temp reading when I turn the car on to accessory (usually it'll say like 85 or 93 or close to whatever the tempature is outside - assuming the coolant is at an ambient temp after car has been sitting for a day) but when I start the motor the analog gauge pegs MAX hot and the DIC gauge reads "xxx" for the temp.
Any reason it would do this?
I check the connection on the plug and it works fine... There are no blown fuses, so I assume I got a faulty sensor? what else could it be?
Old Jun 24, 2009 | 04:27 PM
lucky131969's Avatar
lucky131969
We installed a new one and now I get a coolant temp reading when I turn the car on to accessory but when I start the motor the analog gauge pegs MAX hot and the DIC gauge reads "xxx" for the temp.
You can do one of two things to reset the condition. Clear everything out of the DIC, or disconnect the battery cable for a minute, and reconnect.
Old Jun 24, 2009 | 05:37 PM
RideZX6R's Avatar
RideZX6R
*edit* - new coolant sensor fixed the issue.
To Coolant temp sensor issue...
