Tire size?
Old Jun 25, 2009 | 07:13 PM
ASP5's Avatar
ASP5
Cruising
Default Tire size?
I want to buy a set of Kuhmo XS tires for street/autocross for my C5 w/ ZO6 wheels. They come in 315/30/18 for the rear and 275/40/17 for the front. Is a 30 in the rear too low profile? I have read that it should be a 35 so you can maintain the .8" or .9" or so stagger higher in the rear so as not to affect the ABS. I don't have active handling so that is not affected. The rears would actually be .22" diameter shorter than the fronts. Will that affect my ABS and Traction control since they will be my street tires too? Thanks
Old Jun 25, 2009 | 07:27 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yes, it will definitely screw up your traction control.
The profile number is not an absolute, it is a percentage measure of the tire's sidewall compared to it's width. A 255/40/17 would work fine on the front with that size rear tire (for example)..the profile number is the same, but the narrower 255 will be short enough to compliment the 315/30 rears.
When searching, focus on overall tire height (diameter), not so much about the profile number. Keep the rear tires slightly taller than the front, and you'll be fine.
Old Jun 25, 2009 | 09:49 PM
Bill Dearborn's Avatar
Bill Dearborn
You will trigger the TC with that tire ratio. TC will not even let you coast in nuetral with the rear tire being smaller than the front it will apply the rear brakes to try and slow down the rear tires.
Bill
To Tire size?
