Another temp ext sensor question
Old Jun 25, 2009 | 08:41 PM
pear's Avatar
pear
Ohio Events Coordinator
St. Jude Donor '09
Default Another temp ext sensor question
I searched this one and found nothing to match this. When I start the engine the ext temp comes up somewhere in the low sixties when I know it's in the 80's. Then it will slowly drop to a random temp, often as low as 40 then slowly head to the correct or vey near temp. Doesn't sound like a big deal since it will finally get there.... Well while it thinks it's cold it won't throw cold air, but seems to throw heat . Makes sense that it wants to heat, and not cool but what is going on with the outside temp? I cleaned and check the connection to the sensor Thanks Randy
Old Jun 25, 2009 | 08:43 PM
poolboy's Avatar
poolboy
If you checked the connector to the external temp sensor first, and if they are OK the sensor itself is most likely dying.
Old Jun 25, 2009 | 09:30 PM
C7cmnthru's Avatar
C7cmnthru
Likely the sensor. Friend had same problem with his 00 C5. Dealer tried to sell him a new control/head unit. It turned out to be a $15 part
Old Jun 25, 2009 | 11:46 PM
lucky131969's Avatar
lucky131969
Always check the sensor connector for corrosion first. Very common. Use a DMM to check resistance to ground as well.
Old Jun 29, 2009 | 11:42 AM
HarryO's Avatar
HarryO
Can someone tell me exactly where the senser is located. Mine is also giving strange readings
Old Jun 29, 2009 | 12:16 PM
byronhunter's Avatar
byronhunter
Under front bumper, right side.
To Another temp ext sensor question
