Replacing front bumper lens
Old Jun 26, 2009 | 06:26 AM
tehedd's Avatar
tehedd
4th Gear
Default Replacing front bumper lens
I need to replace the factory lens and wanted some how to...
Old Jun 26, 2009 | 08:39 AM
MYLS6's Avatar
MYLS6
Got this so you can change the bulb, but I think that its vertually the same process to get the light housing out also...
1) Jack up the front of the car, and put jackstands underneath.
2) Remove the front fascia lower closeout panel.
3) Remove the brake caliper cooling duct from the front fascia, then reposition the duct.
4) Remove the socket from the lamp assembly, then remove bulb.
At this point remove whatever hardware holding the lense inplace and swap out... Hope this helps
Old Jun 26, 2009 | 09:37 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Go here:
http://forums.corvetteforum.com/c5-t...with-pics.html
Page down to post #3, it will tell you everything you need to know.
Old Jul 20, 2009 | 06:26 PM
tehedd's Avatar
tehedd
4th Gear
I must say this is the best forum imagiable. Thanks so much to everyone offering such needed info. Especially to those of us that are mechanically challenged.
Old Jul 20, 2009 | 07:23 PM
buoniconti81's Avatar
buoniconti81
1... pop up lights manualy
2... take light out and cover
3... put hand down below with socket and remove...
I did it that way alittle tight but it worked....
To Replacing front bumper lens
