dead battery??!
Old Feb 11, 2002 | 10:09 AM
zeus337's Avatar
zeus337
Cruise-In II Veteran
Cruise-In III Veteran
Default dead battery??!
Is it NORMAL when a vette sits for 6 weeks in the winter time, to have a dead battery when you try to start it?
AND does jump starting it with another car possibly damage electrical or any other part of car, because i have hear jump starting is a NO NO? :confused:
Old Feb 11, 2002 | 11:46 AM
carpe dm's Avatar
carpe dm
Default Re: dead battery??! (zeus337)
Welcome to the C5 "black curent", dead battery soap opera! Yes it seems to be normal. If you are afraid of a direct jump, take the battery out and charge it. Best bet: get a Battery Tender and use it every time ytou car will sit for more than a few days. :yesnod: :) :smash:
Old Feb 11, 2002 | 12:13 PM
speedwaywhite's Avatar
speedwaywhite
C5's have key-off drain. Some systems remain powered up when ignition is off. Battery tender is the best solution. Delco batterys because of their construction don't stand cycling (repeated charge/discharge) if your battery has needed recharged many times I would replace it. Good Luck!
Old Feb 11, 2002 | 01:40 PM
zeus337's Avatar
zeus337
Default Re: dead battery??! (speedwaywhite)
i have never recharged this one and i used a jump start to get her running, i just hope that did not do anything to the car.... what is this "black current"?
how does this battery tender work? :confused:
Old Feb 11, 2002 | 04:12 PM
BLUBYU2002C5's Avatar
BLUBYU2002C5
Mine has been in the garage for the last 6 weeks, went out
this weekend found a dead battery also, just trickled charged
it back up and away we went...
I thought gm had a shut off or something after
10 mins (except for the clock memory) :confused:
Old Feb 11, 2002 | 04:33 PM
speedwaywhite
Battery tender will monitor the voltage of your battery and charge when needed , float when not needed.You can connnect the tender,plug in to household current and forget about it.
Controlmodules on you C5 won't like the spikes of current that can be generated jumping. The alternator on the car is designed keep your battery up not to charge a very low battery, it could self-destruct trying to charge the battery.
Old Feb 11, 2002 | 05:20 PM
JHS5YDO's Avatar
JHS5YDO
Sears has a similar charger for about $30, the Battery Tender is about $50. I have been using it for about 2 years -- works great. :cheers:
Old Feb 12, 2002 | 10:01 AM
zeus337's Avatar
zeus337
Q. since i jumpstarted the car is there something i can do to test and see if it did damage anything?
also can you connect the battery tender to the battery without taking it out or unhooking it?
Old Feb 12, 2002 | 10:02 AM
zeus337's Avatar
zeus337
if the car is shutoff is the alternator working?
To dead battery??!
