00 vette overheating
Old Jun 29, 2009 | 06:07 PM
geforce6688's Avatar
geforce6688
6th Gear
Default 00 vette overheating
Hi, my mom came home today and said that the gauges said somthing like coolant temp high, I check it out the thing is at 255f (so says the digital gauge, the analog is in celsius). I was like holly ****, So I turn it on and the cooling fans are on and the temperature lowered to about 148 and wouldent really go any lower, so I shut it off and letting it cool of this way. My first guess is that the thermostat is fubared/stuck because the temp wouldent lower with the coolant flowing. How should I go about fixing this? I can drain the coolant and replace the thermostat, but Should I test stuff first or could it be the water pump or such? When the car was running I could see coolant pouring in to the tank on the top (overflow tank?) Thanks.
Old Jun 29, 2009 | 06:11 PM
99FRC Newb's Avatar
99FRC Newb
clear the leaves/garbage bag out from in front of the radiator
Old Jun 29, 2009 | 06:20 PM
geforce6688
6th Gear
I looked under the front where the condenser is (the only place where the leaves can get stuck?) and there was only a little bit of crap in the corners, but can more get stuck elsewheres?
Old Jun 29, 2009 | 06:55 PM
99FRC Newb's Avatar
99FRC Newb
between the condenser and the radiator
Old Jun 29, 2009 | 07:05 PM
timemender's Avatar
timemender
Water pump is most likely pumping from what describe.
If the thermostat is stuck a small amount of water may flow, but not enough to cool.
Are the fans working? Both fans? Turn on the air-conditioning; this should cause both fans to run continuously at normal engine temps.
If the coolant is old that could be the cause or at least contribute to the problem.
Yes debris accumulates between the radiator & condenser AND in the fins of both. If this is determined to be true, you can remove the upper radiator support (after removing the intake above the radiator) to get a better look of what’s in there. Smaller debris will be difficult to see as that type can hide in the fins themselves. GENTLY flush water and/or compressed air back through the fins (engine compartment out towards the front) to remove most of the debris.
Wear safety glasses, especially if using compressed air. Work carefully so as to not damage the radiator or condenser.
Old Jun 29, 2009 | 10:15 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Good advice from Timemender
Old Jun 30, 2009 | 03:31 PM
FormerBiker's Avatar
FormerBiker
Not to scare you but when mine started running hot I had a blown head gasket.
But check the simple stuff first. If you cannot track it down, have someone take a sample of the coolent and take it for a gas analysis. That's how they found my problem.
Old Jun 30, 2009 | 07:45 PM
geforce6688
6th Gear
Went out and bought a thermostat, and am gonna try that even though it seems the coolant is flowing. Also when I start the car the top little tube that looks to be coming from the radiator to the top of the coolant tank is always pouring into the coolant tank even when cold, but I dont know if thats normal or not, but I checked identifix and most people reported trying thermostats and it eventually being the water pump.
Also im gonna check in between the rad and condenser, see if theres crud in there like you guys said.
Old Jun 30, 2009 | 08:32 PM
geforce6688
6th Gear
Ok, looks like there was a good amount of crap in there, like pollen and grass and ****, so I hit it with air as best I could but the fan shroud is in the way so I cant blow it towards the front of the car. You sure it would be ok to flush it with water? I think I am gonna go to harbor freight and see if they got like a 2 ft long blow gun to get between the fan shroud and radiator.
Old Jun 30, 2009 | 09:17 PM
dgrant3830's Avatar
dgrant3830
Yes, you can use water. I created a real simple water wand with 1/4 inch copper tubing and a hose to tube adapater from a home store. Works real nice and costs next to nothing.
Old Jul 2, 2009 | 08:58 PM
geforce6688
6th Gear
Cleaned out the radiator, drove it around and it hit 245 again, I felt the bottom hose coming from the thermostat and it wasent real hot like the top hose was, so im going to be replacing the thermostat tomorrow, will post results.
Old Jul 2, 2009 | 09:08 PM
Conk's Avatar
Conk
Or, he said sheepishly, a WalMart bag. Nearly blocked the whole surface area!
Old Jul 4, 2009 | 04:28 PM
geforce6688
6th Gear
Ok, drained the coolant at the pet **** on the bottom of the radiator, about a gallon and a half came out, replaced the thermostat, filled it up with about another gallon and a half, runs at 190-195 now. Seems to be all fixed, and now I dont have to worry about the radiator being clogged up for a while now.
Old Jul 4, 2009 | 05:07 PM
lucky131969's Avatar
lucky131969
Ok. What you removed should have been a 50/50 mix, and what you put back in was straight coolant?....or was it pre-mixed?
To 00 vette overheating
