tcc lock during shifts
Old Jul 1, 2009 | 08:02 PM
c5mtl's Avatar
c5mtl
Default tcc lock during shifts
guys table d2801 ...what do you think??? allow lockup during upshifts or not....trans builders say dont do it
Old Jul 1, 2009 | 08:36 PM
dougbfresh's Avatar
dougbfresh
Why would you lock it up? Lockup is for high speed Overdrive operation.
Old Jul 1, 2009 | 09:07 PM
c5mtl's Avatar
c5mtl
im just asking ....i dont know what it supposed to be.....im using efi live to check my tune and its set to allow....ive been messing with way to much stuff and i think i changed that table
Old Jul 1, 2009 | 09:18 PM
dougbfresh's Avatar
dougbfresh
Maybe you ought to research how thing were designed to work before you change them??
Old Jul 1, 2009 | 09:24 PM
c5mtl's Avatar
c5mtl
true ...but not messing with anything really dangerous....
Old Jul 1, 2009 | 10:20 PM
zz28zz's Avatar
zz28zz
I disabled it on my F-body. It just didn't feel right, especially after stiffening-up the tranny (lots of mods during re-build).
Old Jul 2, 2009 | 06:35 AM
dougbfresh's Avatar
dougbfresh
Old Dec 23, 2009 | 11:46 AM
Rconce01's Avatar
Rconce01
I like messing with things! and i don't have EFI live. I did this about a year ago and i learned my lesson.
I was curious like you and i decided to analyze how the circuitry works. I found the wire that when grounded would cause the lock up to engage no matter what the PCM tried to do. You will get a TCC stuck on code from your PCM. See the way it works is the TCC solenoid always recieves 12v positive and when the pcm feels the TCC should engage it provides the negative and it engages.
It was really fun driving around with it engaged the car felt just like a manual car no slippage in the torque converter. Although you had to disengage it when you come to a complete stop if not the car will turn off. I redlined the car with the TCC on and the traction off in 1st and when it slammed second not only did i almost loose complete control of the car, it got a mega wack down the drivetrain. Nothing broke and i drove it like that for a while.
the 3rd gear Zpack gave out after a year on my A4 and I had it rebuilt and left the TCC under normal operation.
It was a fun little gadjet to play with, that can cause tranny failure.
Old Dec 23, 2009 | 02:31 PM
dougbfresh's Avatar
dougbfresh
I worked in a trans shop long ago and did silly stuff like this, it was always fun till it broke the trans. and eventually it ALWAYS BROKE THE TRANS.
Old Dec 23, 2009 | 06:13 PM
byronhunter's Avatar
byronhunter
Do I have a hard time reading something in that?
Old Dec 24, 2009 | 06:45 PM
Rconce01's Avatar
Rconce01
but its fun!!!!
To tcc lock during shifts
