Drivers side mirror
Old Jul 2, 2009 | 05:59 PM
Pres712's Avatar
Pres712
Default Drivers side mirror
My son's '04's drivers side mirror is "de-laminating"? I think it's due to being hooked up to the inside mirror that self dims. How does one go about fixing that problem? Buy a whole new ***'y or can you just replace the mirror?
Old Jul 2, 2009 | 11:46 PM
Choreo's Avatar
Choreo
You can replace just the mirror, just have to be careful when installing new mirror - wear heavy gloves as there is always a chance of the glass my break when applying the pressure needed to re-attach to pivot, motor pegs and sensor pegs.
Old Jul 3, 2009 | 05:03 AM
Blown 346's Avatar
Blown 346
My mirror is doing this as well. It is actually the fluid inside it that is causing the problem. Becareful if you remove it or replace it, the fluid inside the mirror will remove paint if it makes contact with it. I would suggest having GM replace it. Just the glass is a little over $300. Thats why I still have the problem.
Old Jul 3, 2009 | 10:54 AM
tlgarst's Avatar
tlgarst
Mine did the same thing. I bought whole mirrow asm from a junk yard for $150 and snapped ot the mirrow.
Still cheaper than buying new from the dealer.
To Drivers side mirror
