New cam
Old Jul 3, 2009 | 12:45 AM
harry_ss's Avatar
harry_ss
Default New cam
Hi!
I have a 2001 z06 completely stock, only borla exhaust.
And now i want to buy a fast lsx 92mm and 92 body throttle and a new camshaft.
i was looking for a ms4, but is too big, so i decided for the ms3 from TSP, or the 233/239 111 LSA.
So my question is: wich of those (ms3 or 233/239) will be the best for my vette. Is the MS3 too big for daily drive??
I will be grateful for your answer...
Harry.
Old Jul 3, 2009 | 04:59 AM
Blown 346's Avatar
Blown 346
If that is all the motor work you will have then eiter would be fine. If you want a blower then you will need a blower cam, and they arent that big.
The cam wont be too big for a dailyt driver, its if you want to hear it rumble and shake the car all the time. If you dont mind that and the noise from it go for it. Remember to get new valve springs, and hardened pushrods.
Old Jul 3, 2009 | 11:31 AM
harry_ss's Avatar
harry_ss
Ok thanks!
will there be any valve clearance issues using the MS3 or another problem to worry about??
Old Jul 3, 2009 | 12:04 PM
Rich@pm-fl.com's Avatar
Rich@pm-fl.com
The MS3 is a great cam. I wouldnt say that it is too big for a daily driver, but that is up to interpretation.
Old Jul 3, 2009 | 12:36 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
G5X3 all the way
Old Jul 3, 2009 | 01:36 PM
harry_ss's Avatar
harry_ss
Originally Posted by schpenxel
G5X3 all the way
I saw it at lmperformance.com but there isnt specs about it.
Old Jul 3, 2009 | 01:49 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Specs are on LG's website although they're a little secretive about the exact specs. Do a search on here or over on ls1tech and you should find out a lot about it. It's a great cam but I believe requires flycutting the pistons so it may be too big for what you're wanting to do.
Old Jul 3, 2009 | 04:58 PM
Blown 346's Avatar
Blown 346
Ok thanks!
Like another memeber stated fly cutting valve reliefs in the pistons would help out greatly. Otherwsie there is a risk of smacking valves.
Old Jul 3, 2009 | 05:08 PM
aweil's Avatar
aweil
Why is the MS4 too big?
Old Jul 3, 2009 | 08:28 PM
corvette8189's Avatar
corvette8189
G5X3 all the way
get the G5X3, thats what i got and its awesome.
you do not need to flycut for the X3
specs are around 234 242 600 610
Old Jul 6, 2009 | 06:22 PM
harry_ss's Avatar
harry_ss
Is necesary to flycut the pistons with the MS3?
Old Jul 6, 2009 | 07:57 PM
aweil's Avatar
aweil
Not with stock heads.
Old Jul 6, 2009 | 08:25 PM
harry_ss's Avatar
harry_ss
Ok thanks
Old Jul 6, 2009 | 08:30 PM
harry_ss's Avatar
harry_ss
How many rwhp on my vette??, with the MS3, FAST lsx 92mm. intake manifold, and FAST 92mm body t.
thnks for your answers.
Old Jul 6, 2009 | 08:51 PM
sami85L98's Avatar
sami85L98
How much rwhp on my vette??, with the MS3, FAST lsx 92mm. intake manifold, and FAST 92mm body t.
421 Rwhp
Old Jul 7, 2009 | 09:57 PM
harry_ss's Avatar
harry_ss
Good numbers but I thought could make more horsepower.
Old Jul 7, 2009 | 11:09 PM
txFRC's Avatar
txFRC
ms3/4 is a great cam. so is the Trex. but they are suited more for top end all out hp and high rpm shifting and work best on cars with big gears (3.90+).
driving around the street in stop and go traffic and burst, you might get out run by a little TR224 cam, cause he's making way more power/tq under the curve than you are.
something to consider. i'd pick the cam on what kind of driving your going to be doing. be it hwy runs, at the track on a tire, or playing around on the street.
my guess with those other mods. probably in the 450-460hp range. do you have headers yet?
To New cam
Old Jul 7, 2009 | 11:23 PM
harry_ss's Avatar
harry_ss
yes
Old Jul 8, 2009 | 02:08 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
My 2001 M6 made 413.8 RWHP with AFE II CAI, MS3, dual springs, hardened push rods, ported throttle body, LG Pros, no cats, Stingers, tuned with EFI Live. Stock heads and stock LS6 intake manifold. On two different dynos with 2 HP difference between to two.
Old Jul 8, 2009 | 09:24 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
I am going to go against the grain here and recommend you look into an ECS blower cam. The cam has great drivability characterstics and makes great power under the curve.
There is a post on here of a member's car that was a Z06 with bolt-ons and ecs cam w/ stock heads. Put down 430 rwhp!
You might find the following link helpful.
http://www.ls1tech.com/forums/genera...cam-guide.html
I would recommend not getting a cam that requires you to fly-cut the pistons. Pistons are one of the weak points on these cars as it is. No sense making it worse.
