hvac codes u1160 and bo338
Old Jul 3, 2009 | 02:12 PM
deathraceking's Avatar
deathraceking
Default hvac codes u1160 and bo338
hey guys
i'm having some cooling problems on my 02 z. i had the a/c compressor replaced but its still not cooling like it should.the passenger throws more air and is a bit colder than the passsenger side.i researched the problems and most people have problems with the actuators which also throw codes B0441 and B0361; however i'm getting codes u1160 and bo338, any ideas on a fix?Thanks
Old Jul 3, 2009 | 06:46 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Sounds like your inside temp sensor... is it Current?
Old Jul 4, 2009 | 07:16 PM
deathraceking
i know that code bo338 is the inside temp sensor,what do u mean by "is it current"? i wonder what the other code "u1160 " means.
Old Jul 4, 2009 | 07:35 PM
tstar's Avatar
tstar
U Codes are acommunication code, they can be ignored and are common.
Does the B0338 have a C or H after it?
Old Jul 5, 2009 | 02:02 PM
deathraceking
oh ok i will ignore the u code, the other code appears as bo338 hc.What does the letters mean?I appreciate your help!!!
Old Jul 5, 2009 | 02:46 PM
tstar's Avatar
tstar
"H" = History
"C" = Current
Typically you can ignore a History Code also, it might be something to keep a log of in case there's additional codes that pop up in the future, it might help the diagnoses better.
A Current code is one that requires your immediate attention... I believe since you're showing both a H and C that it malfunctioned in the past (but before the the 40 or so ignition cycles that it takes to clear a code) and it is currently faulting out again.
Check the connection and wiring before just throwing money at it!
Tim
To hvac codes u1160 and bo338
