Although I think they are a great bargain for a street application, do NOT use these rotors for track events. I tried one of these with one OEM rotor on the opposite side, and the slotted/drilled rotor CRACKED while BARELY BROKEN IN. I had actually just returned from bedding a 2nd set of pads on the rotors, maybe 30 min of track time on the original set, when I heard "pinging" from the brake area. Sure enough, the outermost hole on several of the 'rows' of holes cracked out to the edge of the rotor.
I was hoping for better metalurgy, but I guess that it is not to be.
Thanks for the info... I am not buying any more stock or stock looking brake rotors or any stock brake stuff for my car anymore!!! Everything I have ever had that resembles the stock stuff has broken, cracked or wore out very fast!! :(
Well, hopefully your problems will finally be example for people who don't understand. Drilled rotors are for looks, not racing. :nonod: Drilled rotors are much more prone to cracking under stress, and you won't see many hard core racers using drilled rotors. Outgassing is no longer a problem with new pad technology, so the holes are just for looks.
Thanks for posting your results! :)
Thats the problem, pro's know the holes are not a good thing on stock style rotors, but then big companies, GM included now offer drilled ones for sale!! Heck, I ordered the Durastop perf rotors for my Blazer, and was WAY disappointed when they came and were not drilled/slotted as advertised and told by the dealer. Guess really I am glad now though.
As far as the stock braking system goes, I don't think you're really going to see an overall improvement with aftermarket rotors on the track. They cost a bundle more, and even though they might last longer, you end up behind in the end since the stock (or HD) rotors are so inexpensive. If you're sticking with stock calipers, you're not going to see an improvement in braking anyway. I guess you might get better heat disipation with a premium rotor though (not sure if aluminium hats are an improvment in heat transfer to the hubs or not).
Hmmm... let me see... dang! I've gotten 12 track days so far on my original stock rotors! I was using stock pads, now I'm testing EBC's Green Stuff compound (not good enough for a heavy car like the C5 on the track) so my pads aren't all that agressive (although I do run race rubber).
I think the only thing that would help these rotors is to be thrown in the trash. Drilling of the holes after the casting is part of the problem... the other part is that the metal is sub standard for extreme usage. (not that I ever drive my car like that) ;)
