Headlight Trivia - Gear Grinds / Stuck
I closed the headlight finished the job and it poped up the first time no problem. When I went to shut them off it goes down flush completely with the hood and then starts grinding. Tried to adjust the manual **** and it still grinds every time it go to shut the headlight.
For now I turned it up all the way and its stuck in the raised position.
Please help, is there an adjustment on the headlight. The motor works fine and it pops up and down perfectly. Just grinds once its flush.
Please help. Thanks in advance!!!
If so your gears are done. Time for some brass gears: http://www.rodneydickman.com/corvette.html
Follow this DIY: http://forums.corvetteforum.com/c5-g...placement.html
Do what he said
