Turn SIgnal Problems
Old Jul 7, 2009 | 09:31 PM
aserdikoff's Avatar
aserdikoff
3rd Gear
Default Turn SIgnal Problems
I am having a problem with my right rear turn signal. I have checked the bulbs and both are working. If I use the flashers they bulbs work and with the light on or off the bulbs work. When using the turns signal I get a fast flash which I thought meant a bad bulb.
Can someone please help
Old Jul 7, 2009 | 09:57 PM
rws.1's Avatar
rws.1
bulbs are cheap... change them.
It is possible that the one of the filaments is broken but occassionaly makes contact and works.
Old Jul 9, 2009 | 10:30 AM
drew47000000's Avatar
drew47000000
I have the same problem with my left rear. Change the bulbs. If that doesnt work, its very likely that you have a bad Multifunction 'stalk' switch. Sorry to bear such bad news, but I'm in the same boat
Old Jul 9, 2009 | 10:52 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Also try cycling the hazard switch several times.
Old Jul 9, 2009 | 06:26 PM
hornet7's Avatar
hornet7
Default Turn signal lights
Something to think about. I had that problem on my 82 S-10. The dealer pointed to a bad blub in the door. Something about total impedance. Chaeck all your bulbs.
To Turn SIgnal Problems
