Checking tire pressure sensors
Old Jul 10, 2009 | 04:37 PM
vette.mix's Avatar
vette.mix
Default Checking tire pressure sensors
I just replaced the batteries on a couple of (97-99) tire pressure sensors. Can I check these outside of the tires to see if I replaced the batteries correctly, I have 1 wheel that does not have sensor in it.
Thanks for any help in advance
Old Jul 10, 2009 | 05:49 PM
my6thvette's Avatar
my6thvette
You can check to see if they are communicating, with a magnet, while setting in the drivers seat. They don't need to be mounted in the wheels.
Old Jul 11, 2009 | 04:28 AM
VET IT B's Avatar
VET IT B
You can check with a volt meeter before you cover up the new batteries with potting material.
Old Jul 11, 2009 | 07:08 AM
Blown427conv's Avatar
Blown427conv
What is the magnet test I keep hearing about on these?
Old Jul 11, 2009 | 10:04 AM
Bakersfield's Avatar
Bakersfield
The magnet activates a small reed switch inside the sensor. That in turn wakes up the sensor and it communicates with the receiver making it is "trained" and it confirms that with a horn honk. You then mark the sensor as to which tire location it goes and move on to the next sensor.
To Checking tire pressure sensors
