Stock throttle body size
Old Jul 11, 2009 | 10:58 PM
fhturner's Avatar
fhturner
Default Stock throttle body size
Had a bit of confusion when selling the throttle body off my '01 Z06 parts car. The buyer wondered if it was 78mm, and I figured he was trying to determine if it was 78mm vs. 90mm LS2. So I said yes. But he measured it and says it is 75mm. I've seen both #s in the past, but I've never known for certain what the actual stock measurement on an LS1/6 TB is.
So, can anybody tell me for sure? Since ALL C5 TBs from 2000-2004 are the same part #, then mine *ought* to be the same size as all of those years. Is there a difference in TB size from early C5s to later C5s? What size _should_ my TB be?
Thanks,
Fred
Old Jul 12, 2009 | 12:48 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
The stock TB for a 2000 to 2004 Corvette C5 and Z06 (DELCO # 217-2288 and GM # 17113669) is 78mm. I believe the 1997 to 1999 (GM/DELCO #17113564) were 75mm.
Old Jul 12, 2009 | 05:26 PM
fhturner's Avatar
fhturner
Thanks for the response! Do you have any way to verify this info? Or is there a sure-fire way to check part #s on the TB itself? I just find it strange that my '01Z would have a 75mm TB on it. Granted, the car was a salvage car w/ a checkered past, but still seems odd to me that someone would have put an older TB on the car. Plausible, but strange...
Old Jul 12, 2009 | 05:45 PM
Gray Ghost GS
If the C5 Z06 was a salvage car w/ a checkered past you may want to check the VIN on your engine to verify its an LS6 vs. an early model LS1, which might explain the 75mm
Old Jul 12, 2009 | 11:42 PM
fhturner's Avatar
fhturner
Hmmm...yeah, I still have the block (was hydro-locked when i got the car), so I might check that out. However, the heads were the correct 243 casting, so if it _is_ a 75mm TB, I'm guessing someone had something else on top-- different manifold and TB perhaps-- before and then swapped before calling the insurance company...
Old Jul 13, 2009 | 10:06 PM
fhturner's Avatar
fhturner
Received the TB back today, and compared it to the one on my '99 LS1 that's for sale. The outer diameter is a perfect match. However, they have different #s stamped on them. The '99 has 25179793 stamped on it. The "mystery" TB shows 25317951. I can find virtually no information on either, as they are not proper GM part #s. How certain are you (or is anybody) that the TB size changed from 75mm to 78mm in 2000?
Old Jul 13, 2009 | 10:09 PM
Gray Ghost GS
Contact Gene Culley (Forum Vendor for GM Parts) - he can verify the 97-99 and 00-04 TB sizes 75mm vs. 78mm. I could be wrong....
Old Jul 13, 2009 | 10:26 PM
fhturner's Avatar
fhturner
Good idea! Thanks!
Old Jul 15, 2009 | 09:14 PM
vettezeke's Avatar
vettezeke
Default Throttle body 17113669
I just bought a new throttle body # 17113669 which was suppose to be the 2000 to 2004 piece for Z06 as well as LS1 and the blade and the hole where the blade sits both measure 2.950" . Which times 25.4 mm per inch is 74.93 mm, or about 75mm. I thought that they were suppose to be 78mm? Anybody else have any input?
Old Jul 15, 2009 | 11:33 PM
happa's Avatar
happa
This is interesting. I didnt know there was a differance, thought they were all 78mm
Old Jul 16, 2009 | 12:51 AM
fhturner's Avatar
fhturner
Interesting...very interesting! My guess is that they are ALL 75mm. I had never heard of a 3mm increase for any year until I had this come up. And since the main engine change in C5 happened in 2001, it didn't make sense to me that the same TB part # would be used starting in 2000 (rather than '01) thru 2004.
In any case, a 3mm change probably wouldn't affect much anyway, but my guess is, any references to 78mm TBs are referring to an aftermarket piece, perhaps, or measurement from a different spot on the TB. Can you provide us the #'s that you see etched in the metal?
Thx,
Fred
Old Jul 16, 2009 | 09:17 AM
vettezeke's Avatar
vettezeke
A 75mm throttle body would have 92% the area of a 78mm if there was a 78mm. The 2000 to 2004 have a diferent part number than the 98 to 99 ones.
Old Jul 16, 2009 | 10:53 AM
SuperTom's Avatar
SuperTom
a few of the TB borers I read make it 78 mm so they must start at 75 then get bored to 78 but I dont really know for sure
Old Jul 16, 2009 | 11:18 AM
fhturner's Avatar
fhturner
Right, but despite the different part #s, I'm thinking now that they are all 75mm, no matter what year. And my '01 TB should be the same part as the one you just bought. Are you able to spot the #s etched on yours?
Thx,
FT
Old Jul 16, 2009 | 11:48 AM
vettezeke's Avatar
vettezeke
Default Throttle body numbers
Yea I can read them, but not till I get home tonight.
Old Mar 14, 2021 | 12:43 AM
touring2's Avatar
touring2
Can anybody tell me why my 2001 Z06 TB measures , yes, I measured it, 92mm at the inlet where it connects to the air bridge? thank you.
Old Mar 14, 2021 | 09:26 AM
helga203's Avatar
helga203
This is a 2009 thread so these member might not be on the forum anymore. But why can't an old thread come to life again??
Becayse we always seem to make jokes.
Sorry i cant hjelp with ?
To Stock throttle body size
Old Mar 14, 2021 | 09:34 AM
Gordy M's Avatar
Gordy M
The LS1 TB will flow a tad over 750 CFM and the engine at readline will flow about 630 cfm. The Z06 flows over 650 cfm as I recall. We had the chief engineer from the engine plant as a guest speaker back in 2000 and he gave a talk to our club about the new, at that time, Z06 engine details. The above is from my 20+ yr memory and I believe I put it in an early 2001 thread.
Old Mar 14, 2021 | 10:47 AM
bonesbrakr's Avatar
bonesbrakr
Besides the fact that the thread is 12 years old, maybe its an aftermarket intake and therefore an aftermarket throttle body? Or a LS2/LS3 throttle body?
Old Mar 14, 2021 | 10:51 AM
helga203's Avatar
helga203
