MAP Sensor Limp Home Mode
Old Jul 12, 2009 | 03:03 PM
rad_vet's Avatar
rad_vet
Default MAP Sensor Limp Home Mode
My 2001 z06 recently went into Limp Home Mode with ECM flashing code P0107 with various other loss of communications U codes. I found one of the wires to the MAP sensor was broken. I fixed the wire and the car is now running normal. I want to be sure I fixed the cause of the Limp Home Mode. Just to verify, can a broken wire to the MAP sensor cause the car to go into Limp Home Mode?
Thanks.
Old Jul 12, 2009 | 10:50 PM
vettesrnice's Avatar
vettesrnice
not sure of that but I began to over heat due to air entraped in the cooling system and it put my car in limp.
