Battery drain reference
Old Feb 13, 2002 | 01:10 PM
Fast one's Avatar
Fast one
Default Battery drain reference
The battery drain current at rest was measured at 20ma or 0.020 amps on a 1998. When an ammeter was first hooked up the current draw was 1.1 amps, then 880ma, then 80ma and finally 20ma, all within a minute as the computer turned things off. The underhood lightbulb was unplugged for this test. At a 20ma drain, a decent battery should hold a charge for a month; longer storage requires the battery to be disconnected. The glovebox door was left open and the test repeated; after 15 minutes the current dropped to 20ma after the computer shut the power off to the glovebox light. Anyone questioning why their battery went dead in a short time needs only to check the current draw and compare to 20ma.
Old Feb 13, 2002 | 02:29 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Battery drain reference (Fast one)
thatks for the info; I printed this one for future ref.
Old Feb 13, 2002 | 04:39 PM
jerryv's Avatar
jerryv
This is good info .. thanks.
To Battery drain reference
