Raptor Dual Mode Shift Light?
I see that tach signal can be gotten from the wires under the dash.
Even the acc power and ground I think? Not real clear on that part.
Now can the VSS signal also be gotten at this location?
From Raptors site...
Vss signal is at PCM, red connector (C2), pin # 50, dark green with white stripe wire.
It appears from pictures that there is a wire at this location marked that way. Is it the same wire?
I would like to grab all the needed wires in one location if possible? Easier cleaner install...
TIA for any help..
No I do not have it apart just now. But thought I might try this weekend.
But with the dual mode you need the VSS also. Or at least from what i have read.
Just thought that might be under there also? Just assuming that all or most the wires there go to the PCM?
TIA..
