Close lightning strike,,now getting codes??
)!! The next day started getting traction control,,ABS and active handling messages. Have been driven it several times,,clearing codes and throwing new ones,,,the baffling thing is they are not very consistent on the codes! The only regular one is 28TCS--1232. Sometimes it adds BCM--B2723 and sometimes BO RFA U1096 & U1016 and once U1096. Never threw ANY of these before!?! Battery never drops below 12.8,12.9 at the terminals,,alt shows 14.2(give or take a few points) at the terminals shortly after start up. Any ideas,comments or suggestions??? Gene
A lightening strike near the car could have generated a sufficiently high electrical surge to damage the electronic modules in the car but you need to check the things that are the most common causes of this code first.
Bill
Bill
). Can get it up on the lift and check as many sensors and grounds as I can find(read Bill's sticky at the top). It has been spending quite a bit of time outside as the attached garage is out of commission for the time being,,the strike is the new wild card here,,and that is my worry that the electromagnetic field could have overloaded a computer. the strike was potent enough to blow several chunks of concrete out of the driveway curbing,,not very far from the car. The odd thing is my pick-up was parked next to the tree and was OK!! Have several little things I want to do while I'm under there. I have a digital multi-meter,, can you give a description on how to check resistance?? I've torn many motors etc. apart,,LOTS of mechanical things,,but am a REAL green horn with electrical stuff outside of voltage testing and stuff like that. Thanks,,Gene
!! So I'm really undecided as this is a very strong suspect to just call a coincidence! Not saying it isn't,,but it was a very powerful strike. The drive is bordered by 6"X8'' X7 ft. concrete lentils,,,and it blew the ends off of 4 of them. Never had codes ever(car has almost 71K),,,except for the good old infamous column lock last year. Then the next day codes,,,it does make you suspicious!! Got to find out how to do a resistance as tomorrow I'm putting her up on a lift and try to check everything I can find!!
I would try disconnecting the bat, then clear the codes again. Maybe use a professional scanner and start checking sensors in real time. Try swapping a new ECU?
C1232 LF Wheel Speed Circuit Open or Shorted
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
I would get down to the wheel and look for something suspicious on that wheel speed sensor. I wouldn't think the static would have got it, but anything is possible. Says its shorted out therefore needs to be looked at right away. Clean the pellet on your key and lastly, check out the star connector down adjacent to the BCM.
Just joking man. I hope you get it all worked out.
Since this damaged your driveway and electrical items in the house it may be covered by your auto's comprehensive insurance the sameway as the household items are covered by your homeowners insurance. Hopefully, you have a low deductible on the comp. Talk to the insurance agent before you do any real work on the car.
Bill
