Gear ratio when in 3rd....
Old Jul 16, 2009 | 09:28 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default Gear ratio when in 3rd....
Ok, I am trying to learn more about the dif. I have a 2.73 A4. From a dead stop, as I go through the gears, what are my ratios? AT highway speeds when I put it in 3rd it is much more responsive...this tells me I am in a different ratio, but what is it? This all has to do with my decision to move into a 3.42 setup.
Old Jul 16, 2009 | 10:28 PM
Munch's Avatar
Munch
St. Jude Donor '10
I believe this is correct for an A4 with 2.73 gears but I am in no way an expert. I'm sure others will chime in.
1st 3.06
2nd 1.63
3rd 1.00
4th 0.70
Reverse 2.29
Old Jul 16, 2009 | 11:25 PM
4DRUSH's Avatar
4DRUSH
No matter what rear gear you have, 3rd gear in the trans will always be 1:1
At 75 mph in 3rd gear with 2:73's your RPM will be 2,730
At 75 mph in 3rd gear with 3:42's your RPM will be 3,420
No problem though, since you have OD
Old Jul 17, 2009 | 01:04 PM
$$$frumnuttin'
aw yes, I get it...I was getting the gears in the rear end confused with the gears in the tranny. So, the extra time gain comes from the combination, right? If someone posts the numbers for the 3.42 it should be evident, right?
Old Jul 17, 2009 | 06:24 PM
David426's Avatar
David426
The transmission gear ratios will never change no mater what rear end axles ratio you have. You have an 4l60e automatic transmission.. They all have the trans ratio that MUNCH posted above. The auto trans either had a standard 2.73 or optional 3.15 ratio from the factory.. The 3.42 rear end was standard on all manual trans mission c5 corvettes... The manual Transmission ratios are also different than the auto trans ratios Also the transmission gearing is shorter on the z06 than on the regular c5 6 speeds.. Both have the same 3.42 rear end.. The z06 has a close ratio transmission, which provides for quicker acceleration than the wide ratio 6 speed found on the coupe,frc and convertble.. The close ratio tranny keeps the engine in the "sweet spot"
of the powerband for optimal power at all times. So all said you are stuck with the same tranny ratios regardless if you havee a 2.73,3.15,3.42,3.73,4.10 axle ratio. The 3.42 gears will help your acceleration times out quite a bit.. I think you will be really happy with it.. A 3200 rpm stall converter woul be a nice addition as well
Old Jul 17, 2009 | 07:02 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I went from a 2.73 to a 3.42 ZO6 rear.There was a huge difference in performance. There also was a difference in gas mileage. With the 2.73, I averaged about 29 mpg straight highway. Now, I get about 25mpg. HOWEVER, that may be due to the fact that it is WAY MORE FUN TO DRIVE THE CAR NOW, and the tune I have is pretty aggressive. I have a hard time not getting on it from time to time just for the kick it gives me.
Also, if you switch to a different rear, you MUST GET A TUNE. Get one from someone famliar with A4 trans. I know folks will say any good tuner can handle this. NOT. The first guys that did the rear install did a tune that sucked. Chuck, at Corvettes of Westchester got the car running great.
I did not get a different TC ( torque converter), and the car is still fine for the street. Everyone claims you need this, but it is not true.If I spent alot of time at a drag strip, a different TC like a 2800 0r 3200 would probably be the way to go. It will also cost you about another grand to get this too.
Old Jul 17, 2009 | 10:15 PM
$$$frumnuttin'
Great stuff...just wondering, couldn't my dealer's corvette mechanic do the shift point adjustments with the tech 2? I may have him install it...
Old Jul 22, 2009 | 03:25 PM
Ralphyboy's Avatar
Ralphyboy
I don't think dealers do this gear swap,since it is not an authorized option from GM to put a 3.42 in an A4. I don't know where you live, but there has to be a vette shop near that will do the swap and know how to tune it. Post up in your local area in the events section and ask who had this done, and where they went.
Old Jul 22, 2009 | 08:38 PM
$$$frumnuttin'
I'll check that out. they have done aftermarket repairs for me, e.g. an Autozone water pump. Also, they put in Z06 shocks and swaybars, and gave me a Z06 alignment, so I am pretty sure they will do the rear end as long as it is a GM part they won't be concerned. I am a repeat customer too, so that helps...they always tell me to enjoy me Corvette...I like that!
Old Jul 22, 2009 | 10:11 PM
Ralphyboy's Avatar
Ralphyboy
When they give you the bill, i'm sure "they" like that. The mods you refered to are minor things.
I would still take the car to a private "vette specialty" shop for gears and a tune. GM dealer will only give you a "GM" tune, not a custom tune .
Old Jul 22, 2009 | 11:49 PM
$$$frumnuttin'
I hear ya.
Old Jul 23, 2009 | 11:08 AM
Mike Mercury's Avatar
Mike Mercury
the dealer won't be able to do the reprogram with this scenario. Oh yes... they each have the famed "Tech Tool 2" but the menu won't allow one to select a value for an unsupported upgrade. The TT2 - when connected to an A4 C5... will only allow the selection of 2.73 or 3.15 (because that was the available factory ratios on the A4).
The 3.42 selection is grayed out.
Old Jul 23, 2009 | 12:01 PM
Ralphyboy's Avatar
Ralphyboy
Thanks Mike for explaining what I was thinking, I think ?
That's what I meant to say. GM only offers 2.78 or 3.15 as ratios for an A4. A 3.42 is not a GM option for an A4, so it would not be a mod a dealer would do, and their basic software would not give them the ability to account for this ratio in your car.
Like I said, talk to some local vette guys, and find out who they use in your area. That is the best way to go for this mod.
Old Jul 23, 2009 | 12:28 PM
$$$frumnuttin'
The problem is I would have to leave my 'baby' overnight somewhere in the madness! If I could find one that would let me help out or just hang around for the switchout I would jump on it. The labor and working overhead is just too much for an old man like me
Old Jul 23, 2009 | 12:30 PM
$$$frumnuttin'
thanks for the explanation...but I never say never...I will ask...they have 2 corvette mechanics, one of them does all the performance work....you never know.
Old Jul 23, 2009 | 09:49 PM
Ralphyboy's Avatar
Ralphyboy
Any good shop can do the gear swap in a few hours, and then do a tune for you. You go in first thing in the morning, and after lunch you are out the door.You just need to let the gears break in if you are getting a new setup. You have to wait a few hundred miles before you can jump on the GO PEDAL.
Old Jul 25, 2009 | 04:42 PM
$$$frumnuttin'
I think the dealer will do it...I'll know for sure Monday...as long as I give them the VIN of the car it came out of the Tech2 will work...please keep your fingers collectively crossed for me! BTW, they use Pradators and Hypertechs, they have an extensive collection of them.
To Gear ratio when in 3rd....
