Halltech Venom Onsale!
Old Jul 21, 2009 | 11:59 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Halltech Venom Onsale!
Halltech C5 Venom™ AIS is our newest high performance induction system for the C5. Because of the success of the C6 Venom™, Halltech redesigned our famous Stinger™ intake, starting with the relocation the Delphi 85 MAF sensor to the rear of the intake bridge for better MAF sensor readings less chance of lean codes. Independent dyno testing has shown 311 RWHP/330 lb-ft. just from the addition of this incredible induction system. The bridge is a cousin to the Killer Bee, but allows use of the stock MAF sensor, so no tuning is necessary whatsoever. The biggest change is the use of the Killer Bee™ Filter. This ultra low restriction ISO 5011 Certified filter features a built in velocity stack at the entrance of the filter flange for over 20% gain in airflow over the Warhead filter and dwarfs all comers in its massive size. Our new Venom™ AIS comes in Black or Z06 Red. Bolt on, with no cutting or hacking your shroud. A.I.R. Pump connector hole is now on the bottom of the Killer Bee Filter for that stealth look.
ORDER HERE You can select black or red.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
