Try to fuel up,my Vette develops a "Headache"
Old Jul 22, 2009 | 10:37 AM
K RIPPER's Avatar
K RIPPER
Default Try to fuel up,my Vette develops a "Headache"
Sometimes when attempting to fuel up the old girl develops a "headache" and won't let me put any gas into her the pump keeps clicking off like its full,sometimes if I fool around with it,pull pump nozzle half way out,turn nozzle upside down but when this happens I always must pump real slow but go to same station same pump next day then OK. happens about every 10 fill ups. Had this prob since new 2003 z/06 any ideas anybody???
Old Jul 22, 2009 | 04:10 PM
JEEP/C5's Avatar
JEEP/C5
No problem with my vette but the Jeep will give me fits every so often. Most of the time its one particular pump that is more sensitive than the others so I just dont use that pump and it works fine. If the vent hose is messed up it will trick the pump in thinking its full. I replaced the vent hose on the jeep and it works better.
Old Jul 22, 2009 | 04:38 PM
Bill Dearborn's Avatar
Bill Dearborn
If it was doing it since new it sounds like this should have been repaired under warranty. There was a bulletin about this problem in April 2004.
Vehicle is Difficult to Fill with Fuel or Filling Station Pump Shuts Off Before Tank is Full (Replace Tank Filler Hose) #04-06-04-031 - (Apr 22, 2004)
Vehicle is Difficult to Fill with Fuel or Filling Station Pump Shuts Off Before Tank is Full (Replace Fuel Tank Filler Hose)
1997-2004 Chevrolet Corvette
Condition
Some customers may comment that their vehicle is difficult to fill with fuel or when filling, the pump continuously shuts off before the tank is full.
Cause
This condition may be caused by back pressure within the fuel filler hose. This back pressure trips the fuel nozzle prior to filling the tank, or results in a hard to fill condition.
Correction
Replace the fuel tank filler hose with P/N 10353139. This new hose has been redesigned to provide smoother flow conditions within the section. Use the procedure listed below.
  1. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in the General Information sub-section of the Service Manual.
  2. Remove the left rear tire and wheel.
  3. Remove the left rear wheelhouse panel.
  4. Loosen the lower hose clamp through access hole in body using ¼ drive ratchet and extension.
  5. Loosen the upper hose clamp.
  6. Remove the fuel tank filler hose.
  7. Install the new fuel tank filler hose.
  8. Tighten the upper hose clamp. Tighten Tighten the fuel filler hose clamp to 4N·m(35 lb in).
  9. Tighten the lower hose clamp through access hole in body using ¼ drive ratchet and extension. Tighten Tighten the fuel filler hose clamp to 4N·m(35 lb in).
  10. Install the left rear wheelhouse panel.
  11. Install the left rear tire and wheel.
  12. Lower the vehicle.
Parts Information
Part Number Description
10353139 Hose, Fuel Filler
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor====Description==================== ==============Labor Time
Operation
L1065===Neck, Hose and/or Vent Hose, Fuel Tank Filler -- Left Tank -- Replace== 0.5 hr*
Bill
Old Jul 23, 2009 | 10:17 AM
K RIPPER's Avatar
K RIPPER
Bill thank you forthe reply AND for taking the time w/detailed info should have had fixed under warranty but was infrequent problem whch I attributed to overly sensitive fuel nozzles and as there are dual tanks I just felt that this was just the nature of the beast.Doesn't seem like too tough of a job ,friend suggested i keep a small section of 2x4 in car as he has same prob. which happens at his local gas station where he fuels up quite often he said he drives up onto the 2x4 w/l rear tire and it tilts the car enough so fueling is ok as I don't have prob at neighborhood gas station I think I would look pretty silly doing that. Again thanks
Old Jul 23, 2009 | 10:41 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
thats pretty funny having to stop at a gas station, get out, lay a 2x4 on the ground and drive on it in front of everyone. or worse, you drive on it and the tire spins and kicks it out 100 feet so you have to run and get it
dude, just have it fixed
Old Jul 23, 2009 | 10:51 AM
tramminc's Avatar
tramminc
[QUOTE=K RIPPER;1570873699]Sometimes when attempting to fuel up the old girl develops a "headache" and won't let me put any gas into her the pump keeps clicking off like its full,sometimes if I fool around with it,pull pump nozzle half way out,turn nozzle upside down but when this happens I always must pump real slow but go to same station same pump next day then OK.
This sounds like a old girl friend I had once
Old Jul 23, 2009 | 10:54 PM
K RIPPER's Avatar
K RIPPER
Ikester,gonna fix it the right way,no 2x4 4 me funny last time I had to carry something for my car was 17 my 2nd or ? 3rd car a 61 chrys 300 conv. red as gaudyt bas cars got back then car came from fact. with no "'Park".rev neutral 1st 2nd 3rd no park so emer. brake was import. but had these screwy b rakes (lockheed)not self energizing like everybody else had seperate small drum brake at tail shaft of auto trans.people would forget brake was on and destroy them like mine big $$ to fix so I careried bricke in the car w/me if parked on hill would park and throw the bricks at the rear wheels so car wouldn't roll away looked stupid then would look stoopider now putting 2x4 under wheelsof a bitchen car like the corvette I would degrade her that way..........Tramminc...I knew SOMEBODY would see the humor but the prob. is real
To Try to fuel up,my Vette develops a "Headache"
