1999 hdtop a/c problem
Old Jul 22, 2009 | 04:31 PM
snooks's Avatar
snooks
Default 1999 hdtop a/c problem
A/c slowly got warmer. In past was very cold.
Had system recharged, it cooled for a while but never cold then got hot indicative of perhaps a leak in the system.
Could i try a leak stopper additive, recharge system again or is there a common problem with a 10yr old c-5 a/c system i need to know about? Help!
Old Jul 23, 2009 | 12:47 AM
tallboy's Avatar
tallboy
ask the shop that you go th to use a sniffer or die you will find it then
Old Jul 23, 2009 | 08:13 AM
Gideon's_Test's Avatar
Gideon's_Test
Beware the A/C leakstopper! I can clog up the orifice in the TXV. That generally results in a bad compressor...
Old Jul 23, 2009 | 09:00 AM
jodfit's Avatar
jodfit
St. Jude Donor '07
I've read a rash of posts lately about '99 a/c problems, must be an epidemic, I also was a victim, I had my compressor replaced last week, 10 years old, 152,000 miles, leak check revealed it was the compressor shaft seal, a friend of a friend did the work in his shop, $750.00 later, I'm cool again, money well spent IMO.
Old Jul 23, 2009 | 12:12 PM
LoneStarFRC's Avatar
LoneStarFRC
Yeah, those crazy '99s. Ten years old. Whodda thunk?
Btw, I have 157K on mine on the original refrigerant. It's not quite as cold as it once was, but still cold nonetheless. I plan to add about 1/4 to 1/2 can or so this summer.
Old Jul 23, 2009 | 12:21 PM
white90conv's Avatar
white90conv
I used leak stopper in my '90 C4. No more leaks and no other problems. I converted to R134a at the time I repaired it.
Old Jul 23, 2009 | 01:21 PM
LoneStarFRC
I agree with you about the leak stop, but isn't a "TXV" the old term for "suction throttling valve"? Our C5s (and many many other vehicles) use a CCOT (Cycling Clutch Orifice Tube) system.
Old Jul 23, 2009 | 01:39 PM
Gideon's_Test
What I referred to as TXV is the thermal expansion valve...Sometimes is a fixed orifice, or an active throttling valve...Not familiar with the newer technologies. My premise is that the orifice can be clogged/gummed up...When I worked at Chrysler (near the HVAC testing lab), I was told by the test engineer (30+ years experience) that such additives are a bad idea.
Old Jul 23, 2009 | 05:10 PM
LoneStarFRC
I hear ya on the bad idea.
The CCOT setup is a simple, inexpensive, and pretty effective design that GM went over to some number of years ago. Easy to service too. It does however still incorporate a screen (designed primarily to keep metal particles/dirt, etc out of the compressor and the system) but the screen's capacity is very limited and it can still be clogged.
Old Jul 23, 2009 | 06:20 PM
corvette Mark's Avatar
corvette Mark
my freon leaks out from comp front seal. going in shop soon.
To 1999 hdtop a/c problem
