Leaf Spring question
Old Jul 22, 2009 | 05:13 PM
flyinc5's Avatar
flyinc5
Cruising
Default Leaf Spring question
Does anyone know if there is a difference between normal 98 C5 vette leaf spring and a C5 Z06? I will say having a cracked spring helps the car 60' pullin 1.4's
Old Jul 22, 2009 | 05:38 PM
lionelhutz's Avatar
lionelhutz
Yes, the Z springs have a little higher spring rate.
Peter
Old Jul 22, 2009 | 07:22 PM
flyinc5's Avatar
flyinc5
Cruising
would it work on a c5 and be better or worse? Mine is cracked and I got a Z spring for $50
Old Jul 22, 2009 | 07:49 PM
IMD's Avatar
IMD
standard C5 spring rates:
Front- 440 Rear- 576
Z06 Spring rates:
Front- 525 Rear- 714
it would probably be better for road handling, but slightly worse for drag racing, because you would get less weight transfer.
Old Jul 22, 2009 | 08:39 PM
MagRedConv's Avatar
MagRedConv
I run C5 Z06 springs and couldn't be happier.
Old Jul 22, 2009 | 10:54 PM
BanditDude's Avatar
BanditDude
You got a good price, but I would not recommend upgrading only one spring. Either a Z06 or Z51 mate would be a better match than the base FE1 item.
Old Jul 23, 2009 | 01:07 AM
longdaddy's Avatar
longdaddy
i don't see how front spring stiffness would make any difference under acceleration - you are unloading the spring, not loading it when you are transferring weight to the back.
you will change cornering dynamics by using mis-matched setup. since you got a great deal, might be worth giving it a try and seeing if you like it - if not you could always resell the spring here and get matching front spring or a full z06 setup.
Old Jul 23, 2009 | 09:42 AM
IMD's Avatar
IMD
the guy never actually said if he was talking about his front or rear spring.
Old Jul 23, 2009 | 12:27 PM
longdaddy's Avatar
longdaddy
good point, i assumed he was talking about front one as that is the one i have seen cracked.
To Leaf Spring question
