Aircondition Problem help!!
Old Jul 22, 2009 | 08:22 PM
filsvet's Avatar
filsvet
Default Aircondition Problem help!!
aircondition problems- first i get hot air in the drivers side cold air in the passenger side. second i cant get the vent to change air comes out of all the vents them now i notice when i try to turn the air on it wont come on plesase so i get air out of all vent hot air in one side and now air wont turn on this is on a 1998 c5 vett i did check the freon and it is full anybody please help!!!!!
Old Jul 22, 2009 | 10:30 PM
speedygc5's Avatar
speedygc5
I have the same problem. my dtc codes states that i have a bad actuator. check your codes and reference them on http://www.stengel.net/diccodes.htm that will tell you what problem you are having.
Old Jul 23, 2009 | 12:15 AM
maestro300's Avatar
maestro300
You and me both! Search is your friend.. you'll find dozens of posts on this HVAC issue. You may be able to recalibrate your actuator... though I went through the pain of removing mine and found this was a different design and couldn't recalibrate. May be best to just get a new one and save the time. Check your codes with holding options and hitting fuel four times. Go to HVAC and most likely you'll have the code BO361.
Old Jul 23, 2009 | 12:10 PM
filsvet's Avatar
filsvet
thanks guys i did take the battery off and i found one of the airline broken from acid from the batttery hopefully this is one of the problems
To Aircondition Problem help!!
