Alignment / Steering wheel angle
Old Feb 14, 2002 | 01:27 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Alignment / Steering wheel angle
I had my 98 aligned by the dealer last week. The car feels better now and drives straight as an arrow.
But now the steering wheel is slightly (5 degrees?) off-center when the wheels are straight. Did the tech just get lazy? How difficult is it to reposition the steering wheel so that it's straight now? Any special tools required?
Thanks,
Old Feb 14, 2002 | 02:02 PM
Kenny94945's Avatar
Kenny94945
Default Re: Alignment / Steering wheel angle (SDVette)
Hi SD,
I am with you on this, it seems to me with every car I have owned after an alignement the steering wheel never gets centered correctly and I have to return to the alignment people.
The tech probably wasn't lazy. Some of the computer alignment machines ask you to start by centering the steering wheel.
Anyway....to center one must do/ re-do the toe alignment.
Never have I been able to hold the alignment spec doing this in the driveway. Loosen the tie rod locking bolt and turn the tie rod adjustor equal amounts to center. Then tighten.
I would very much like to read how our other co-members deal with this.
So, I guess the special tool is a toe adjustor measurement tool. I have seen these before (even in JC Whitney catolog) but have never been satisfied that the tool will measure to .5 degrees or be at all accurate.
Kenny
Old Feb 14, 2002 | 02:09 PM
Tom/99's Avatar
Tom/99
I had my 99 Coupe aligned at Corvettes of Houston. When I drove it home, the steering wheel was dead on center. There was a world of difference in the feel of the car, before and after the alignment.
Old Feb 14, 2002 | 06:06 PM
wottogo's Avatar
wottogo
Had the dealer use his new eqquipment to do a 4 point alignment on mine and the steering wheel is centered. It should be do-able. :yesnod:
Old Feb 14, 2002 | 08:47 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Default Re: Alignment / Steering wheel angle (wottogo)
The specs for steering wheel angle is 0 degrees with no variance. I'd get it centered.
Old Feb 15, 2002 | 01:20 AM
01C5fan's Avatar
01C5fan
Take it back to the dealer. They'll fix it.
Old Feb 16, 2002 | 04:00 AM
dbrogan's Avatar
dbrogan
I had the tire shop perform a 4-wheel alignment when I replaced my tires. The steering wheel was off center, as you describe. I took it to the dealership where they aligned it and kept the wheel centered. If at first you don't succeed...
Old Feb 19, 2002 | 02:07 PM
SDVette's Avatar
SDVette
Just a followup to close this thread out...
I took it back and they fixed it in 20 minutes. They did not have to lift the car or remove the wheels..
Chalk one up to Mr. Goodwrench..
Thanks all for the opinions/advise.
To Alignment / Steering wheel angle
