funny valvetrain noise
Old Jul 23, 2009 | 10:56 PM
yellow94coupe's Avatar
yellow94coupe
Default funny valvetrain noise
My dad recently upgraded to Lingenfelter LS6 heads and their GT11 cam. It would make some loud tapping about 5 minutes into a drive and only last about 15 seconds and go away. Things ended badly when something failed while it was making a noise. The end of a rocker was broken off, an intake valve was bent, and a retainer mangled. Hard to say what broke first. To play it safe, he replaced the lifters, pushrods, and rockers with new stock parts. Now the car is back to tapping again and it is starting to last longer than 15 seconds and can now be minutes long.
The only things that are the same are the heads themselves, the cam, and the shop that did the work so we are wondering what it could be. What could be some possible causes?
Old Jul 24, 2009 | 10:46 AM
yellow94coupe
Anybody?
Old Jul 24, 2009 | 11:16 AM
95BlueBomber's Avatar
95BlueBomber
When the heads were removed did he have them decked? What all work was done when the heads were at the machine shop?
Old Jul 24, 2009 | 01:25 PM
Blown427conv's Avatar
Blown427conv
Possibly incorrect pushrod length...
Old Jul 24, 2009 | 01:41 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
what length pushrods did he use?
Old Jul 24, 2009 | 02:04 PM
95BlueBomber
If the heads were decked I would imagine pushrod length as well. If it had a bent valve I would assume you had the heads gone through. I would check the wipe pattern or get an adjustable pushrod and check the length.
Old Jul 24, 2009 | 02:09 PM
yellow94coupe
I would assume Lingenfelter would have the quality control not to use a decked core.
The heads supplied by Lingenfelter should not have been decked and weren't decked by the shop. The stock pushrod length was used, but I doubt the shop went through the trouble of verifying it. I called Lingenfelter and they said that was fine as long as the heads were not decked by the shop and the gasket is the stock thickness. That is why I don't think the shop double checked.
It was the Lingenfelter 480 hp package so the LS6 heads were ported and polished, port matched, and had a valve job.
If the pushrods are indeed the incorrect length, wouldn't there be a tapping all the time rather than some of the time?
Old Jul 24, 2009 | 02:13 PM
95BlueBomber
Im confused... I thought it had the lingenfelter package on and then bent the valve. So the heads have not been removed since the lingenfelter package?
Old Jul 24, 2009 | 02:26 PM
Blown427conv
Thermal expansion would play a part in them tapping only after it got warm. When the steel push rod reached temp after the aluminum castings it would stop tapping. Only a theory though.
Old Jul 24, 2009 | 02:51 PM
yellow94coupe
I thought of that as well, but that seems like it would tap consistently when cold and gradually go away as it heats up or be quiet cold and get louder as it heats. This noise seems to come and go.
Old Jul 25, 2009 | 09:27 AM
95BlueBomber
When its there does it seem to be in one place or moving around? Again its hard to say without knowing some details, if the valve bent the valve seat could be messed up if there was no valve job done afterwards.
Old Jul 25, 2009 | 02:34 PM
ArKay99's Avatar
ArKay99
I vote for incorrect pushrod length. If you used non-decked heads and a stock thickness head gasket using a stock length pushrod would be correct. However an aftermarket cam with higher lift lobes requires a smaller base circle. That means the lifter will sit lower in the bore when traveling on the heel and consequently the lifter preload amount will decrease.
One other possibility would be oil aeration due to a pinched o-ring. If the oil pump was removed when the cam was pulled it's possible that the o-ring was either re-used or got pinched when it was re-installed. I'm not saying this is the cause, but it will cause your symptoms.
Old Jul 26, 2009 | 12:03 AM
yellow94coupe
He had the Lingenfelter package on for like 2000 miles and then it bent the valve. The head was removed, given a valve job and new valve, and reinstalled.
Old Jul 26, 2009 | 12:05 AM
yellow94coupe
He thinks it is from one stationary area and the valvetrain noise gets about 5x louder. It seems to be coming from the driver's side whereas the busted valve head was the passenger side.
Old Jul 26, 2009 | 08:05 AM
Atok's Avatar
Atok
Obviously valve to piston clearance issue. Is the cam timed correctly? Is it off a tooth? If he keeps driving it with the noise and damage you described he's risking destroying the engine if it drops the valve.
How about valve springs? Do you have correct seat and nose pressure per the cam specs?
Old Jul 27, 2009 | 12:27 PM
yellow94coupe
It is back at the shop, but they don't know what could be wrong. They said they degreed the cam so I would assume it wouldn't be off a tooth.
The valve springs are the high lift kit from Lingenfelter that is required with the GT11 cam. Not sure about seat pressure and all.
Old Jul 27, 2009 | 12:29 PM
yellow94coupe
He says it sounds like this video except if he rev's it, it sounds like it misfires.
http://www.youtube.com/watch?v=FdBa44L_6b4
To funny valvetrain noise
