C5 Climate control issue beyond dim display
Old Jul 24, 2009 | 01:26 PM
mvette66's Avatar
mvette66
Default C5 Climate control issue beyond dim display
Please help! I did the C5 climate control resister resolder and when testing found the display screen to be back to life but all the lamps except the LED's where dead and found this which looks to be a resister blown and missing a big chunk of it so I can not read the number on it. The picture below is from the other thread on how to fix the display. If someone has their's apart, could you give me the # off it and any info on what it is and what it does would be great.. The bottom line is I need the # and it needs to be replaced as it is for sure bad.
Thank you for any help you may give,
Mike
