c5 to c6 shifter
Old Jul 26, 2009 | 06:28 PM
joece5's Avatar
joece5
Default c5 to c6 shifter
Anyone know If a z06 short throw shifter from a c6 will fit on a c5??
Old Jul 26, 2009 | 07:04 PM
hotwheels57's Avatar
hotwheels57
yes.
Old Jul 26, 2009 | 08:24 PM
MTPZ06's Avatar
MTPZ06
Originally Posted by hotwheels57
yes.
Agreed...just note that the shift ***** for C5's and C6's are not interchangable.
Old Jul 26, 2009 | 10:10 PM
joece5's Avatar
joece5
I like the shift **** on the c6 so if I can make the swap I will go for it.. Thanks for the help.. Might I be better off going stock or aftermkt??
Old Jul 27, 2009 | 11:43 AM
hotwheels57
The question is subjective. It gets asked literally hundreds (probably thousands?) of times along with every other "what's the best...?" question.
To prove that point, in C5 Tech, use search or search this forum (in the red banner). Use keywords "c5 shifter" or similar.
The after market offers billet construction and some with the ability to adjust the lever angle, or remove the lever, or replaceable bias springs. They after market usually has shorter throws because of their construction. Some of them cause more noise/vibration into the cabin as well as stiffer ("precision") shifting.
The oem C5/Z06 and C6/Z06 shifters are virtually identical in construction, ie stamped steel with rubber noise/vibration isolation. An oem shifter from '97 to current production '09 C6/Z06 will interchange. The oem C6/Z06 shifters have the laid back lever and much more ergonomic **** than the C5/Z06 shifters. That's what most people like about them over C5/Z06.
Within the multitude of past threads, try to find just one thread where there is a consensus of opinion. It won't happen. Some owners change their shifters as often as they do their shorts.
The best advice is to drive as many other C5 Corvettes with various shifters as you can. Maybe a local club? Then chose which one you like "the best".
HURST, B&M, MTI, KIRBAN, C6/Z06, MGW, BREATHLESS PERFORMANCE, CALLAWAY, PRO 5.0, are just a few of the "best" that I remember from past threads...
Old Jul 27, 2009 | 10:28 PM
joece5's Avatar
joece5
bought the stock parts today. Dont know if I should get a new boot or use the old one though>
Old Jul 27, 2009 | 10:51 PM
ajcorvettes's Avatar
ajcorvettes
You can use the stocker, you just have to modify it. search C6 shifter install. I just did this swap and really like it. Good luck
Old Jul 30, 2009 | 09:34 PM
joece5's Avatar
joece5
Easy as pie literly didnt even finish a beer. Under 30 minites and I dont know why I waited so long. Thanks to all for the help!!
To c5 to c6 shifter
