IPC Malfunction After CLB Install
Old Jul 26, 2009 | 11:00 PM
jxhx502's Avatar
jxhx502
Default IPC Malfunction After CLB Install - Please Help!
Hey everyone. I've spent the last couple hours doing searches for my particular issue, and haven't had any luck. Hopefully someone out there has experienced my problem and can recommend a remedy.
I installed the CLB from Corvettes of Houston this afternoon. After the installation, the DIC was prompting the "Service Column Lock", so I proceeded to reset the BCM with the removal of fuse 23. All is well now with the steering column, but the IPC buttons completely quit on me. They don't beep, and none of the buttons work. Geesh...if it's not one thing, it's another... Any help is much appreciated. Thanks in advance.
Old Jul 27, 2009 | 10:43 PM
jxhx502's Avatar
jxhx502
Originally Posted by 8VETTE7
Have you checked fuses 19 and 25?
Yes, I checked both fuses and both are fine...
Old Jul 28, 2009 | 04:42 AM
jxhx502's Avatar
jxhx502
Without the buttons working you obviously cannot pull up any codes. I looked at the shop manual and it instructs connecting a Scan Tool ( Tech II) and obtaining codes and then use the tool to perform the operation of the buttons.. Short of that I might uninstall the CLB and see what if anything that does and/or disconnecting the battery for at least 10 minutes in the hope that the BCM got into some confused state that a reset will clear.
Thanks 8VETTE7! I really appreciate your help. I don't have a Scan Tool, so I'll try uninstalling the CLB and/or disconnecting the battery for a BCM reset. Thanks again!
To IPC Malfunction After CLB Install
