BLOWER ON A 70K MI. MOTOR?
Old Feb 14, 2002 | 09:59 PM
aces's Avatar
aces
Default BLOWER ON A 70K MI. MOTOR?
My motor doesn't burn any oil , think a blower will hurt it? Should I rebuild it if I only run 7 psi? :flag
Old Feb 14, 2002 | 10:35 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: BLOWER ON A 70K MI. MOTOR? (aces)
aces, before I would dump blower $$$$ into a car with 70 k on the speedo, I would do a valve job, and a re-ring, and new brearings.......
Why dump $5/$8k into something you have to tear down 2 months later......not worth the chance in my opinion :yesnod:
Old Feb 14, 2002 | 11:22 PM
DARTH VETTER's Avatar
DARTH VETTER
Default Re: BLOWER ON A 70K MI. MOTOR? (ZO6LS6)
I would definitely freshen up the motor first.
Old Feb 14, 2002 | 11:32 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
I say slap some forged pistons in it, new rings, bearings, lower the compression ratio, buy the race version of the ATI supercharger and run 12#'s! :D
Old Feb 14, 2002 | 11:34 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: BLOWER ON A 70K MI. MOTOR? (MattG)
:yesnod: :yesnod: Now we are talking!! :eek:
vetterdstr
Old Feb 15, 2002 | 03:58 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I had only 15k on mine and decided to go with peace of mind. With a blower you could detinate in the tuning process and blow it right there. Take the hit up front and enjoy it down the road! Good luck!!
JB
Old Feb 15, 2002 | 09:23 PM
aces's Avatar
aces
Default Re: BLOWER ON A 70K MI. MOTOR? (jbsblownc5)
JB
Seems like it could blow any time any way If it detonates.
The motor has less than 2% leakdown. That's the same as a new motor.
Any other opinions?
Old Feb 16, 2002 | 12:53 PM
Paul Scarpelli's Avatar
Paul Scarpelli
If you've changed your oil often and you haven't ragged out the engine, you're fine. I added an S-Trim Vortech to an LT1 that had 45,000 miles, and ran it for two years, then sold it to a guy in Houston who got another year out of it...before the crash. If you do not get greedy for that additional 20 horsepower that you cannot reliably get, you'll be okay. Mr. Detonation is not our friend! When there's any question, run less boost, less timing, and less revs.
Been that; done there... :confused: :D
Old Feb 16, 2002 | 02:08 PM
DoctorV8's Avatar
DoctorV8
Default Re: BLOWER ON A 70K MI. MOTOR? (Paul Scarpelli)
Though it's not an LS1 or even a Chevy, I put a centrifugal s/c on my 5.0 liter mustang when it had 100,000 on the motor and 20,000 miles on the heads, and ran it for 2 years....now it has a twin turbo setup, making 510 ft lbs at the wheels on 10 psi, with 135,000 on the shortblock (with factory forged pistons).
Of course, I sweated the details of a proper fuel/ignition system, and a conservative tune. That is the key to longevity, not mileage.
Old Feb 16, 2002 | 11:03 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
70k really isn't to bad for an LS1 motor. If you were getting close to 100k I'd suggest freshening things up a little. At that point you midas well just rebuild for some big boost numbers as Matt suggested. If motor has been taken care of and has strong compression I don't see any problem with it. I have guys with over 50,000 supercharged miles on their LS1 and they are still going strong.
Tom
Old Feb 18, 2002 | 03:17 AM
aces's Avatar
aces
Default Re: BLOWER ON A 70K MI. MOTOR? (tbyrne)
Maybe I'll just run 5lbs. until it becomes a bottom breather.Most of the miles are freeway miles which should be easier on the motor anyway.
Old Feb 21, 2002 | 02:13 AM
aces's Avatar
aces
then again maybe I won't. 45 hp difference
Old Mar 6, 2002 | 02:28 PM
IAdvise's Avatar
IAdvise
I say blow it
Old Mar 6, 2002 | 10:46 PM
aces's Avatar
aces
Default Re: BLOWER ON A 70K MI. MOTOR? (IAdvise)
I say blow it
I have fowarded your harrassing emails to the police.
again , ronwhite aka iadvise......leave me alone.
Old Mar 7, 2002 | 01:04 AM
BLISS's Avatar
BLISS
Cruise-In II Veteran
Cruise-In III Veteran
:confused: :confused: :confused:
What is going on between you two ? Actually, nevermind - I don't wanna get involved :nono:
Old Mar 7, 2002 | 01:40 AM
RonWhite's Avatar
RonWhite
IAdvise you to blow it! What was wrong with that? You really are far to sensitive. Please work with your therapist on this. I really think you should add the blower!
Old Mar 7, 2002 | 02:15 AM
aces's Avatar
aces
Default Re: BLOWER ON A 70K MI. MOTOR? (RonWhite)
ronwhite aka iadvise :quit sending me obscene and harrassing emails.
the police have been notified
To BLOWER ON A 70K MI. MOTOR?
