Valve spring question
Old Jul 27, 2009 | 04:01 PM
Munch's Avatar
Munch
St. Jude Donor '10
Default Valve spring question
Never mind, Just talked to my shop and they admitted that they didn't check the springs because they only had 5k miles on them.
I have a shop replacing my heads and they were going to put my old (5k miles) valves and springs in to a new set of heads to save me a few bucks. They now call and tell me that while the car was on the dyno that there was an issue at high rpm which they attributed to the valve springs being worn or "short" as they put it.
My question is this: Wouldn't a reputable shop have tested the springs before putting them in the new heads and wouldn't they have noticed they were short? Also how would one be able to tell the springs are short while they are installed on the head under pressure which is mounted to the block?
Thanks.
