Seat Assist Problems
Old Jul 27, 2009 | 09:09 PM
Tyke's Avatar
Tyke
Default Seat Assist Problems
I recently developed the following problem with my easy exit seat assist:
When I remove the key the seat doesnt slide back to allow the easy exit. However, if I use the control switch on the side of the seat it moves back no problem.
Also, the unlocking of the doors and retraction of steerign wheel works very inconsistently.
What can I check to fix this thanks!
Old Jul 27, 2009 | 10:46 PM
byronhunter's Avatar
byronhunter
Simple things first, check the wireing (2 connectors) left side of driver's seat. Pull the codes and post them here.
Old Jul 29, 2009 | 11:33 AM
Tyke's Avatar
Tyke
Ok tried the seat connector, all looks fine..cleaned it and all...
I was thinking maybe its the sensor that detects when the key is removed that is going bad/dirty.
Anyone know where the easy exit sensor is located and what it looks lie? I want to check it out and clean it perhaps.
Old Jul 29, 2009 | 01:33 PM
dougbfresh's Avatar
dougbfresh
Sure it's turned on via the DIC??
Old Jul 29, 2009 | 03:21 PM
Tyke's Avatar
Tyke
YEs...like I said the doors unlock and the steering wheel retracts (not always but often) but the seat never goes back.
Old Oct 20, 2010 | 09:45 AM
scottyk5's Avatar
scottyk5
5th Gear
Did you find a fix? I have the same problem! Everyrthing else works and it is turned on in the DIC, FOB is programmed too, but the seat just stopped moving back for me to exit out of the blue.
Old Oct 20, 2010 | 05:28 PM
DeltaBravo's Avatar
DeltaBravo
How old is the battery? I had some similar issues that were fixed after I replaced the battery.
Old Oct 21, 2010 | 12:44 AM
scottyk5's Avatar
scottyk5
5th Gear
Haven't thought of that. I will put a new battery in when I get back to the states in December and see if it does the trick.
To Seat Assist Problems
