need brake bleed sequence
Old Feb 15, 2002 | 02:54 AM
blue98coupe's Avatar
blue98coupe
Default need brake bleed sequence
going to install bias spring and need to bleed brakes , any help out there ??? thanks guys
Old Feb 15, 2002 | 05:49 AM
Jochen's Avatar
Jochen
Default Re: need brake bleed sequence (blue98coupe)
If you just need the sequence, it should be :
1. Right Rear
2. Left Rear
3. Right Front
4. Left Front
Do you use a bleeder or do you make it the conventional 2 people way ?
Can give you the complete procedure, but have to know the way you do it?
Jochen
Old Feb 15, 2002 | 03:04 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: need brake bleed sequence (Jochen)
My understanding is that there is a difference in the sequence from year to year in the C5 due to some changes in the brake system that are not apparent to us. Suggest you get hold of the Chevy Service Manual for your year to verify.
Old Feb 15, 2002 | 03:12 PM
RedLandRocket's Avatar
RedLandRocket
Default Re: need brake bleed sequence (Gearhead Jim)
Start with longest distance from master cylinder then next longest, etc.
Since the MC is left front the sequence should be RR,LR,RF,LF
Old Feb 15, 2002 | 03:18 PM
Tom/99's Avatar
Tom/99
Start with the longest distance from the master cylinder, right rear, left rear, right front, than left front.
Old Feb 15, 2002 | 09:43 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: need brake bleed sequence (Tom/99)
I know they say its different for a C-5, but I didn't know that at the time. Did the same old conventional methods with two people, no problem. That was last year back in 02/01.
Old Feb 17, 2002 | 09:03 PM
cart3113's Avatar
cart3113
Get speed bleeders and save yourslf lots of time. The things work great. I was able to bleed the entire system in fifteen minutes by myself. Get yourself a sport water bottle. Punch out the plug in the center of the top. Insert one end in the bottle. I used about ten feet so I could see it going to each wheel from the drivers seat. l got mine at Lowe's. You need a small size that will fit fairly tite over the bleeder valve. Stick the other end of the tube into the bottle . Be sure to keep the master cylinder full. You can sit in the car and watch the fluid going throught the plastic (vinyl) tubing. I used two quarts of fliuid to fill the tubing and make sure clean fluid went completely through the system. You still need to do the sequence order. But it is much easier not having to open and close the bleeders everytime you push the pedal. http://www.speedbleeder.com/
Hope this helps,
Jim
Old Feb 17, 2002 | 09:36 PM
Gary2KC5's Avatar
Gary2KC5
going to install bias spring...
FYI: Do you have Active Handling (AH)? The block the spring goes in is a little different for AH cars than non AH cars. Keep in mind that the threads on the block are different on each end. So if a line seems a little tight...it's probably on backwards. Also, don't let air get in the ABS unit down stream. If you do you have to get a dealer to bleed it with a tech 2.
To need brake bleed sequence
