AC/Help....Please
Old Jul 29, 2009 | 01:55 AM
in2fun's Avatar
in2fun
Default AC/Help....Please
Hi All. I have 98 coupe with dule AC controles. On my side ( drivers side ) it blows out some what cool air. On the Passengers side it blows REALLY COLD air. The amount and force of air coming out is the same on both sides. I have both sides set to MAX COLD. The problem stays the same if I do out side air or rec air. I am NOT getting any codes at all and the AC was charged about 3 month ago. Started getting this prob about 3 weeks ago. What do you guys think ?
THANKS !
Old Jul 29, 2009 | 02:14 PM
Blown427conv's Avatar
Blown427conv
As crazy as it sounds, it sounds like it is low on freon. Mine did the same thing when it was low. I've been told the pass side of the evaporator cools first and if the freon is low, it will only cool half of it. I went through a lot of trouble shooting on mine before someone on here told me about this. Sounds like you have a leak...
Old Jul 29, 2009 | 02:27 PM
MaddChopper's Avatar
MaddChopper
St. Jude Donor '09
i agree with blown427. i had the same problem with mine in the beginning of this summer. i had my mechanic run the dye through the system and it didnt show any leaks but it still had the same problem you are having now. anyways i had the mechanic charge the ac just in case and whaaalaa it worked. ac is running 100 perfect again but im pretty sure that come next summer im going to have to charge it again.
Old Jul 29, 2009 | 03:22 PM
in2fun's Avatar
in2fun
Thanks Guys. I'll try charging the AC and see if that helps.
Old Aug 1, 2009 | 12:53 AM
in2fun's Avatar
in2fun
Thanks guys! I charged the AC and now I have "COLD AIR "on both sides... WOO HOO !!!!
THANKS AGAIN !
To AC/Help....Please
