Caliper swap question
Old Jul 30, 2009 | 11:50 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Caliper swap question
I'm swapping calipers from my OEM boring ones to nice shiney powdercoated ones. I've had the calipers off before, but never disconnected the lines for a complete swap.
How is this done?
Old Jul 31, 2009 | 05:08 AM
LoneStarFRC's Avatar
LoneStarFRC
How is this done?
Just disconnect the flex hoses on the frame side first, remove caliper, then disconnect caliper end. Reverse the process for the new ones. Make note of the hose routing beforehand so there's plenty of range-of motion when finished.
Also pay special attention to the copper crush-washers on the caliper end of the hoses. Use new ones. They're cheap and easy to find. I would also recommend buying/borrowing line wrenches for use on any of the brake line fittings. They don't have to be the expensive ones and they can also be used on brake line fittings on the master cylinder if ever needed. You don't even want to contemplate what happens if a regular open-end wrench rounds off a nut.
HTH
Btw, you get them done at Precision?
Old Jul 31, 2009 | 07:51 AM
Gideon's_Test's Avatar
Gideon's_Test
You'll also will need to bleed the air from the lines. If you bleed all four (reccommended) you'll also have the advantage of having flushed your brake fluid. I do not recall the bleed sequence...
Old Jul 31, 2009 | 08:42 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
No, They had a good price, but Mike the powdercoated has a caliper exchange program which means no down-time for my car.
I may let me mechanic do the swap mostly because of the bleeding/flushing. Usually it's just me in the shop I'm no Dr Manhattan. lol
Old Jul 31, 2009 | 10:41 AM
mickey_7106's Avatar
mickey_7106
does he send you new parts or used?
Old Jul 31, 2009 | 10:47 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
How is this done?
It's very similar to doing the Stainless Brake lines replacement. Here is a Write-Up I just did and it includes BLEEDING the Brakes and getting all the air out of the Calipers and new lines
http://forums.corvetteforum.com/c5-g...ll-w-pics.html
It works very well and you'll save some $$ doing it yourself
Thanks,Matt
Old Jul 31, 2009 | 11:59 AM
ttribe's Avatar
ttribe
pretty easy w/ a partner to pump the brake pedal and another bleeding each one.
To Caliper swap question
