AIR system delete/block plate ??
Old Aug 1, 2009 | 06:28 PM
DickieC.99's Avatar
DickieC.99
Default AIR system delete/block plate ??
Hey guys, decided to take out the AIR system. But I have some questions I couldn't find doing a search -
What codes do I need to turn off?
EDIT - Finally found these running a search. Any other codes I need to 'delete?'
P0410
P0412
P0418
P1415
P1416
What thickness stainless steel should I use for the block plate? Where do I get the S.S? I've never bought it before. Do they sell it at Lowes or Home depot?
THANKS!
Old Aug 2, 2009 | 12:23 AM
waddisme's Avatar
waddisme
I got my plates for $13 from I think Speed, Inc. Perfect fit.
Old Aug 2, 2009 | 01:42 PM
DickieC.99's Avatar
DickieC.99
What is everyone using to plug the AIR tube hole in the intake?
Old Aug 2, 2009 | 03:42 PM
vsocks1's Avatar
vsocks1
Originally Posted by DickieC.99
I don't recall the air tube connecting to the intake manifold....
Old Aug 2, 2009 | 06:08 PM
DickieC.99's Avatar
DickieC.99
Sorry, shoulda been more specific. I meant the air filter - the hose that connects on the right side(if standing in front of car looking down at filter) and runs down to the AIR pump.
Old Aug 2, 2009 | 07:35 PM
vsocks1's Avatar
vsocks1
Gotcha!
I used that hole to feed fresh air to my valve covers when I upgraded to LS2 throttle body and needed a connection. If I were to block it I would look for a rubber or plastic grommit the right size. Otherwise you could cut the hose and look for a plug...but that wouldn't look quite as nice! Maybe others have a better idea..
Old Aug 2, 2009 | 07:41 PM
Last C5's Avatar
Last C5
A $0.59 rubber plug from Home Depot.
Old Aug 3, 2009 | 03:15 PM
waddisme's Avatar
waddisme
Damn - I paid $.85 for mine at local hardware.
Old Aug 4, 2009 | 05:40 AM
Bonnetts02Vette's Avatar
Bonnetts02Vette
what are the benefits of pulling out the AIR system?
how much weight does it save?
Old Aug 4, 2009 | 08:57 AM
waddisme's Avatar
waddisme
The weight savings is what it is, but it sure makes working on the motor a lot easier with all that crap out of the way!!
Old Aug 6, 2009 | 12:46 AM
Bonnetts02Vette
how much weight does it save actually? might just remove mine when i do the headers and 2.8H kenne bell in a month
Old Aug 6, 2009 | 05:32 AM
apevet's Avatar
apevet
is there a how to? DIY?
Old Aug 6, 2009 | 08:00 PM
Fratbragen's Avatar
Fratbragen
Old Aug 11, 2009 | 11:37 PM
Fratbragen's Avatar
Fratbragen
Old Aug 12, 2009 | 08:44 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old Aug 28, 2009 | 09:51 PM
Bonnetts02Vette
ttt
To AIR system delete/block plate ??
