stock radio help
Old Aug 4, 2009 | 10:00 PM
warriorp's Avatar
warriorp
Default stock radio help
i have an 01 zo6 that i recently bought...it cam with an aftermarket sony head unit with an amp and a sub that works great just not my cup of tea..the harness had not been cut it and appears to be a professional install...i bought a stock radio from another board member that came from an 02 model...i just installed it and powered it up and it only shows the time...nothing on the tuner and does not respond to any inputs other than the clock and setting the time...i pulled it back out and rechecked all my connections and everything looked good...what do i need to do next? thanks for the help
Old Aug 4, 2009 | 10:44 PM
KOZ's Avatar
KOZ
The radio is in theftlock. Search that and you'll find your answer.There's a 800 number to call and get the unlock code.
Old Aug 5, 2009 | 08:13 AM
warriorp's Avatar
warriorp
it doesnt say loc or anything...but i will try that thanks!
Old Aug 5, 2009 | 08:37 AM
warriorp's Avatar
warriorp
doesnt say loc...held down 2&3 any way and still nothing
Old Aug 5, 2009 | 10:40 AM
KOZ's Avatar
KOZ
Check the fuses then. The ignition/accessory wire may not be getting power. In the radio harness it should be the pink wire.
To stock radio help
