Brake master cylinder question
Thanks for any info, you guys are great!
It turned out that with the reservoir cap off, the fluid ran through the master cylinder, and essentially bled itself. I had to put the cap on to keep the brake fluid from continuing to run through the cylinder so I could put it back on the car. I did push the plunger in a few times, but all I really did was make a bigger mess.
After I got the cylinder back on the car, I cracked the brake line fittings and bled each port. This would have been sufficient for a solid brake pedal, but since I had never flushed the system, I went ahead and bled each caliper until I got clean fluid.
Brakes have worked flawlessly.
My service manual has the procedure for bench bleeding and it actually says to push the piston in "as far as it will travel, a depth of about 1 inch".
I'll try to remember to leave the resevoir cap on when installing the MC on the car.
Thanks for your help also.
