New problems with line lock install???
Old Aug 5, 2009 | 11:16 PM
Ksths2's Avatar
Ksths2
Default New problems with line lock install???
I ended up cutting the stock C5 brake line and got everything plumbed with no leaks. i bled the front brakes and when my wife pushes on the breaks the front wheels stop but when she pushes on the breaks and i connect the positive to the line lock and she lets off the wheels turn again, aka the line lock isn't working.
If you hold your hand on the L.L. you can feel it click but its a very faint click, kinda wimpy so i'm trying to figure out if thats the problem?
Its a $40 Summit special but i can't imagine that'd be my problem since its identical to the hurst & Jegs brand etc....?
I tapped into the brake line on the front of the master cylinder (farthest line from firewall) that is the correct line right? BTW, the line lock is between the master cylinder and the ABS block.
Or does the ABS block have something to do with it not working?
Any help is appreciated.
